2017 fuel filter
Old Jul 4, 2019 | 11:42 AM
Gary O's Avatar
Gary O
2017 fuel filter
Changed fuel filters for first time on 2017@15000 miles, frame mounted filter drained less than gallon out and filter looked new,than under hood filter was fairly tight getting out and put new filter in and turned it to correct position it didn't fit tight,a little play up and down and left and right this normal or am I missing something?
Old Jul 4, 2019 | 06:12 PM
RONMCHUGH's Avatar
RONMCHUGH
Romcjr
Changed mine about a k ago and no problem . I assume the filters are Motorcraft ?
Old Jul 4, 2019 | 06:35 PM
Gary O's Avatar
Gary O
2017 fuel filters
yes,motorcraft filters
Old Jul 4, 2019 | 07:17 PM
Sethcj's Avatar
Sethcj
Do these trucks give you the fuel filter change required on the gauge cluster when they’re in need of being changed?
Old Jul 4, 2019 | 07:23 PM
TeddyD's Avatar
TeddyD
I don’t think they do. I change my filters at 30,000km but that’s 99% highway driving. If I towed more or did a lot of stop and go driving, I’d change them sooner. Your filters only care about how much fuel goes through them, not how far you made it. More fill ups required for that stop and go driving.
Old Jul 5, 2019 | 09:54 AM
mhoefer's Avatar
mhoefer
Fuel filters are every 24,000 Km for heavy service, 8000 km oil changes. Ie every third oil change. No there is no fuel filter warnings for change soon, change now like for the oil life monitor. These are much higher capacity filters so it is an extended change over previous generations, but is based on volume of fuel filtered. Hope you get the seating of the engine fuel filter figured.
stevestroke01
Jun 27, 2011 10:38 AM
mickpowell1967
Mar 27, 2011 09:33 PM
guitarpicr
Mar 10, 2009 10:46 AM
mattpowerstroker
Jan 16, 2008 07:43 PM
spartamouse1
Apr 5, 2002 06:00 PM
