Sponsored by: Real Truck
Trans overheating problems
Old Jul 2, 2019 | 10:08 AM
#Dirty-Livin’'s Avatar
#Dirty-Livin’
I have an 03 250 power stroke , coming home the other day I ended up going down a street that was a dead end , couldn’t turn around so I had to back up a steep hill. About 3 blocks of driving I noticed my trans temp gauge was all the way hot , and my overdrive was flashing on . I had to get out of the street so I went around the block so I could get towed but my trans temp went back to normal , then it dropped all the way cold , and then shot right back up again . I let it sit for a day , tried to again . I could drive it till the trans temp reaches normal warm temps , and as soon as it warms up it skyrockets back up . Any ideas ? It hard shifted a little when the trans temp went all the way up
Old Jul 2, 2019 | 11:14 AM
projectSHO89's Avatar
projectSHO89
Mark K has explained it several times, but the quickest way to AVOID the problem is to put the transfer case into low range when backing up a hill while pushing a load with a hot transmission.
Old Jul 2, 2019 | 11:22 AM
#Dirty-Livin’
So what are the possibilities here so I can fix it
Old Jul 2, 2019 | 11:26 AM
Fefanatic's Avatar
Fefanatic
What doe fluid look like and when was it changed last?
Old Jul 2, 2019 | 11:53 AM
#Dirty-Livin’
Looks decent and changed a few months ago
Old Jul 2, 2019 | 12:31 PM
Rob89's Avatar
Rob89
I’d like to know as well. I don’t have this problem but will surely be mindful next time I need to push a load up a long hill going in reverse.
Old Jul 2, 2019 | 02:00 PM
#Dirty-Livin’
That’s the thing I wasn’t even towing anything I mean I’m 8 1/2 inch lift on 37/s but nothing this transmission can’t take (apparently not )
Old Jul 2, 2019 | 08:30 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The trans temp sensor is bad. It's located in the pan. It's a common failure mode in this transmission.
Old Jul 3, 2019 | 07:14 AM
#Dirty-Livin’
Going to try this and put a new one in today thanks man
Old Jul 3, 2019 | 04:23 PM
#Dirty-Livin’
Yes you were right I changed that , but now I have atf coming out all over the place so I’m changing the gasket tomorrow to see if I can correct the issue , never had a leak before so either I didn’t tighten it enough or somehow the gasket wasn’t aligned properly
Old Jul 3, 2019 | 08:27 PM
projectSHO89
Is the fluid coming out of the pan gasket or out the bell housing?
Old Jul 7, 2019 | 12:05 PM
#Dirty-Livin’
Out of the gasket somewhere , I just put a new gasket on it so I’m going to fill it back up and see if that fixed it
Old Jul 7, 2019 | 02:21 PM
Mark Kovalsky
Did you use a cork or rubber gasket?
tfunk88
Jan 4, 2018 04:42 PM
A/Ox4
Jun 21, 2013 12:06 PM
rmblaster
2009 - 2014 F150
Oct 23, 2011 06:16 AM
embry1123
Jun 24, 2011 02:50 PM
dieselfitter
Dec 5, 2006 04:07 PM
