Trans Temp
Old Oct 19, 2011 | 10:11 PM
rmblaster's Avatar
rmblaster
Trans Temp
Just noticed today that my trans temp allways starts out from cold even after having driven it and it takes a little while to rise up to the temp I checked the other trans gauge same thing do I have a problem or does it really cool down that fast the truck sat for maybe 10 mins
Old Oct 19, 2011 | 11:56 PM
flixden's Avatar
flixden
I would try turning it off and back on immediately, like a second or two in between.
What do you get doing that?
Then, you could move this out and record your readings. A half minute next time, then one minute, etc.
Old Oct 20, 2011 | 01:22 AM
ford390gashog's Avatar
ford390gashog
The gauge is fake anyway so pay no real attention to it. It is programmed to go to 3 settings Cold ,Norm and Overheat
Old Oct 20, 2011 | 07:38 PM
jwill8957's Avatar
jwill8957
Mine does the same I drove all over stopped at my garage started the truck and it was cold until i drove a few hundred yards then it went up. Ive come to the conclusion not to pay attention to the digital guage cause it changes so much
Old Oct 21, 2011 | 04:08 AM
shotgunz's Avatar
shotgunz
I think there is a TSB to address this issue with the 09-10s.
Check here: https://www.ford-trucks.com/tsb/fulltext/index.php
Old Oct 23, 2011 | 06:16 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Agreed! If you are really worried you could install an aftermarket gauge. I had one in my old truck in my 3 gauge pod. Do you tow?
tfunk88
Jan 4, 2018 04:42 PM
System
6.7L Power Stroke Diesel
Aug 10, 2014 03:41 PM
Treker58
Feb 5, 2012 11:43 AM
tritonman2001
Jan 5, 2011 10:19 PM
Grizz49
Nov 23, 2005 07:18 AM
