No start, no wait to start light, turns over but not starting
Ok I have a 99 f350 7.3 that will not start now. Was running fine parked it for a day came back out to go a boom turns over but no start. The frist thing i noticed was no wait to start light and it had been raining and there was some water in my driver's side floor. My bully dog will not read codes for some reason . I have check the fuse for pcm its fine check plugs in back to make sure tight. Even pulled it down road to jump start it still not firing i pluged Block heater and still not firing up help me. Can the glow plug relay make not start i live in the south it hot here
Thank you for your replay. But i have tried the fuel heater and leaving it unpluged all the fuses are good oil pressure good fuel pump is coming on like it should it has blown my mind
I remember coming across this thread and maybe this is the issue? Water leaking from windshield onto fuse block and GEM? Maybe someone with more experience will chime in.
https://www.ford-trucks.com/forums/1...eavy-rain.html
I know you said you checked the fuse, but I'm not sure how you went about it. I would actually physically pull the PCM power fuse out and make sure it isn't corroded in any way. Clean it up with a wire brush regardless. If you're getting water inside, there's a good chance that it isn't the first time and that you have been building corrosion for a while.
Thank you all for the help!
Thanks for all the people who took the time to share your knowledge with me about my truck. Knowledge is power.
My truck is back on the road it was the fuse box its self i guess what one would call pin spread. So i took out the old fuse box and put in one from an 01 that a buddy had for parts he had bought years ago. But once again thank for your time and advice
