Head stud install question.
Old Jun 27, 2019 | 05:14 PM
87crewdually's Avatar
87crewdually
You guys are taking a simple response from a Q & A and treating it like a tech article. Put down your spectacles for a minute. I'm sure the guy knows EVERYTHING has a point where it stretches.
I believe, since it wasn't a direct quote, the author abbreviated the tech's response that the stock headbolts are more likely to stretch (or be stretched) to cause a failure over ARP studs. We all know this.
I don't think we have to be nitpicks.
Trying to do 1 stud at a time on a 6.0 Powerstroke on aged gaskets is not recommended.
Can it be done? Absolutely. Has it been done? Yes. Recommended this day in age? No.
Old Jun 27, 2019 | 07:00 PM
TooManyToys.'s Avatar
TooManyToys.
It’s a point I’ll always nicpick.
Old Jun 27, 2019 | 07:56 PM
brown89ford's Avatar
brown89ford
I think it could be done successfully if the head gaskets are not compromised, but that's going to be a somewhat rare condition".
Why is this a rare condition?
Since there were inquires about the age and mileage (2006 /130K), are you stating that it would be rare situation that this truck has uncompromised gaskets?
fwiw, jumping off the recommeded vs doable train. I personally know someone that has reconditioned and reused head gaskets and those gaskets are still holding. These are on RV hualing trucks....my dad's.
Anyway, I am trying to understand what is doable in regard to installing studs. The reason has been stated, to ensure the greatest reliability possible as I use out of the box X4 SCT tunes. I will likely be deep into the engine inspecting to see if the HPOP fitting has been replaced as well as the other failure prone componenets that plauge 6.0's.
Honestly, I do believe my question has been answered, it is possible and there is good advice wether to do it or not, and how to do it...(I completely forgot about the motormount technique for gaining access).
Anyway, Thanks guys. I have good info to act upon with these responses.
MBDiagMan
Dec 13, 2015 01:52 AM
03powerstrokefl
Dec 16, 2013 02:38 PM
the_auto_tech
Oct 16, 2012 09:44 PM
Dustball8504
Oct 9, 2007 12:11 AM
JReinert
Feb 26, 2006 01:23 PM
