Headstud install questions?
Old Oct 8, 2007 | 08:45 AM
Dustball8504's Avatar
Dustball8504
I'm thinking about doing the headstud install soon just to be on the safe side and was wondering if this would be something I could do myself with relative ease and if so, would it be best to remove the old ones first and then put new ones in or could I just do them one at a time? Is this possible to do with the cab still on the truck or will it be a pain to get to the back ones? Thanks!
Old Oct 8, 2007 | 09:11 AM
04Xcursion's Avatar
04Xcursion
Head studs need to be installed with either the cab off or the engine out; your choice. The rear studs are impossible to put in with the cab in the way. I would not recommend doing them one at a time as the likeliehgood of warping a head is very high. If you're going to that amount of trouble, take the heads off and verify that they're good; put some good gaskets in and do the job 100% so you know what you're dealing with.
This probably not the answer you were wanting to hear, but as far as I know it's the correct one.
Good luck
Old Oct 8, 2007 | 10:50 AM
Dustball8504
Haha, no thats not the answer I would've liked to hear but I'll probably be making the trip to Spartan this winter for some "stuff" and just get it done then, lol. Thanks for the response!
Old Oct 8, 2007 | 08:00 PM
MrMike06's Avatar
MrMike06
There is a kid over at ford-trucks.com that installed headstuds with the motor in and the cab on. Check that site for the thread, he took alot of pictures while he was going.
Old Oct 8, 2007 | 10:31 PM
riggz's Avatar
riggz
Didn't he have to drill a few holes in the firewall?
Old Oct 9, 2007 | 12:11 AM
mulot30th's Avatar
mulot30th
Good luck
Did it that way exept for the heads against strait edge part. Tunrned out to be okay...
