I discovered a rub thru on my battery ground cable on the passenger side battery. I traced the wire to the block below the fuel filter and disconnected it for replacement. I found a light duty wire that was not connected to anything and the terminal lug was corroded/broken. Where does this wire go?? and how important is it?? The issue that got me looking at the cables was slow cranking.
If one of your battery cables failed you should replace all of them. You can get cheapy ones at the parts store or RockAuto. Or you can order online, here are some well rated suppliers:
I make mine out of 2/0 welding cable.
There was a section of the wire that was rubbed thru and corroded green. At only 25% effective, it might cause slow cranking
yep that could cause it for sure.
I make my own cables too, a good Hydraulic Crimper is not very expensive nowadays.
2/0 is plenty large enough too, it's the same size I use, the only place I can find Terminals Locally is at Interstate Battery, the auto stores here just carry Crap Terminals and I wouldn't use those on my Volkswagen
The long negative cable is the ground on the driver's side. The shorter one with 2 pig tails is the passenger side. One eyelet goes to the radiator support, the other goes to the GP relay.
