View Poll Results: Expedition 4x4's [EB] BAD NEG BATTERY WIRE
WHY 4X4 WIRE 160.00 FROM FORD
50.00%
AT THAT PRICE SHOULD IT BE BETTER
0%
hARD TO FIND OUTSIDE OF FORD?
0%
IS IT A PAIN TO REPLACE?
50.00%
$70.00 ON-LINE MOTORCRAFT THE BEST PRICE?
0%
Multiple Choice Poll. Voters: 2. You may not vote on this poll
NEG. battery wire
Old Oct 22, 2003 | 01:49 PM
catchtail's Avatar
catchtail
Unhappy NEG. battery wire
What is it with the neg. battery wire??? Ford wants $160.00 for the wire. I've found some costing less on the internet. The wire cost alot only on the 4x4's why? I think I found one thats a motorcraft for just under $70.00 is that about as good as it's going to get?? Please has anyone had the samething happen?? I don't want to use one of those cheap Q-fix things on there. They always have worked loose at the worst times!! Ford got us with this one [160.00 for a wire ] I'm off road with this exped.EB alot mile from anywhere so it's got to hold up!! Let me know the best place to buy from and it has to FIT. THANKS
Old Oct 23, 2003 | 10:46 AM
buzzard's Avatar
buzzard
What is a negative battery wire? Are you talking about the negative cable that attaches to the block (or frame) and acts as a ground? I have never noticed if it is different from a typical battery cable, but if it isn't, a cable should only cost around $10.
What makes it a $160 part? And why do you think your part is bad?
Old Oct 23, 2003 | 11:09 AM
catchtail's Avatar
catchtail
corrosion from a bad motorcraft battery.. It looks like two wire coming from the connction, but they say there more down below view? I've checked with 2 ford dealers and they say the same.. It's a 98 but with the navig. 4x4's system and 32 V 5.4L which was own by some Ford exec. at the AZ. proving groungs. I bought it as a ford program car, It has [SVT] markings on it. It was a good deal at the time? I do get factory info and Q. sheets every 3or4 months. Mostly from something called [SPECIAL VEHICLE TEAM] but is the neg. battery cable, 2 off the battery then 3to4 out of sight. Beside the rear wiper not working it's been a champ. THANKS
Old Oct 23, 2003 | 03:03 PM
buzzard's Avatar
buzzard
If the connector is bad right around the battery, do you have enough length to cut off the bad section and install a new connector? Just a thought.
randomreview
Mar 24, 2017 12:15 PM
mcali2
1997 - 2003 F150
Mar 16, 2016 05:43 PM
timbuctooCal
Feb 29, 2016 08:26 AM
PRO49FORD
Aug 31, 2015 06:36 PM
ttttmaxx
Aug 18, 2008 08:12 AM
