Front brakes
Old Jun 22, 2019 | 02:51 PM
runsky69's Avatar
runsky69
Front brakes
I replaced the front disc brake pad, rotors were in real good shape. Now the brake pressure is soft and pedal goes to the floor. I checked no leaks plenty of fluid. Do I need to bleed the brakes or did I miss a step? Thanks for the feed back in advance
Old Jun 22, 2019 | 09:47 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I would bleed the brakes. Sounds like there may be air in the system.
Old Jun 23, 2019 | 06:30 AM
runsky69's Avatar
runsky69
Is there a special way to bleed them? I read a different couple things. Thanks
Old Jun 23, 2019 | 06:41 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I do it by myself so I just use the "gravity" method. Start at the right rear and move to the left rear, front right then front left.
Old Jun 23, 2019 | 07:10 AM
runsky69's Avatar
runsky69
Excellent thanks for the help
Old Jun 23, 2019 | 02:43 PM
sonny1965's Avatar
sonny1965
Sounds to me you got the disc brake pads in the wrong location. The one pad with the humps on it has to be in a certain place.if you don"t have them in the right location the brakes will not work correctly. Trust me I did it and was lucky i caught myself.
Old Jun 23, 2019 | 03:39 PM
Siberexpress's Avatar
Siberexpress
There is an inside and outside pad, the inside pad that goes on the brake caliper has to little ears on it.
And after you make sure the pads on on correct do a couple of 55-10 MPH panics stops without stopping to warm them up and then drive a couple miles to cool them off.
Old Jun 23, 2019 | 05:24 PM
rbentnail's Avatar
rbentnail
Get some speedbleeders. Makes fluid bleeding a one man job. I have them on all my vehicles.
https://kirbysbrakebleeders.ecrater.com/
Old Jun 24, 2019 | 06:29 AM
runsky69's Avatar
runsky69
Bled the brakes still same problem. I will recheck pads to make sure I put them in correctly.
Old Jun 24, 2019 | 06:37 AM
tseekins's Avatar
tseekins
Veteran: Coast Guard
If the pedal wasn't spongy before the brake job then it's likely the pad location.
Old Jun 24, 2019 | 09:07 AM
runsky69's Avatar
runsky69
Fixed! The pads were in backwards. Thanks for all the feed back and help..
Old Jun 25, 2019 | 07:40 AM
VintageBikesUSA's Avatar
VintageBikesUSA
I just went though the same thing, had a buddy put on new pads because I was to busy only to find out he had put them in backwards as mentioned above. Should of done the install myself.
Old Oct 26, 2020 | 07:35 PM
dacflyer's Avatar
dacflyer
Well guys,,, I think i may have got my brakes fixed.. haven't road tested it yet.
But i made one mistake.. when you buy a new brake booster... your supposed to adjust the pushrod on the booster. Well my ******* didn't.
I got it adjusted ( been too busy earlier with work and bad weather, or getting too dark so early ) today... the brakes are much better. the rear wheels stop much faster now.
I'll road test it later on this week and report back..
The only thing left that i haven't changed yet was the equalizer valve , Which is made of Unobtanium.. I'm thinking if it needs replaced, i'd have to try and find after market.. Anyone have a link ?
I don't think i'll need it, but a link would be nice, just incase.
MudhenGIB
Dec 27, 2015 11:38 AM
Jules The Great
Feb 18, 2015 08:49 PM
whack&stack
2004 - 2008 F150
Mar 19, 2011 12:04 AM
jleo
Apr 4, 2010 01:29 PM
greythorn3
24
Dec 23, 2006 12:31 PM
