RATS !!!
Old Jun 20, 2019 | 09:17 PM
Dave Chamberlain's Avatar
Dave Chamberlain
RATS !!!
I have 2006 Ford E350 6.0 decommissioned ambulance that I use for my food business, Yesterday it started moved 10 yards and then the engine stopped , started it again and it moved 5 yards , and stopped again, tried to start it again but no start . I removed the cowling inside, only to find a rats nest. I removed the nest and found that some wires had been chewed through. I painfully rejoined the wires , but still a no go. I changed the fuel filter and checked that I had fuel to the secondary filter. The wires that were broken were at a 2 wire connection to the right of the FICM (green /brown ...and white). Any ideas as to what these wires controlled or what the next step would be ?
Old Jun 21, 2019 | 05:08 AM
Yahiko's Avatar
Yahiko
I am a bit tired and can't see straight right now. How ever this PDF should be the diagram for the engine on your rig,
Color codes might not match but it is for the 2006 engine.
Old Jun 21, 2019 | 09:41 PM
SmackDaddy's Avatar
SmackDaddy
If there’s a rat’s nest in there chances are you have a lot more chewed wiring. I’d buy a new harness.
Old Jun 24, 2019 | 11:59 PM
IHateCommieCars's Avatar
IHateCommieCars
Where are you? I have 3 '06 Eseries if you want to compare.
Tide Guy
Jul 5, 2019 11:54 AM
mrbdmorris
Dec 7, 2015 08:03 AM
SAT-LLC
Jun 15, 2011 10:37 PM
redtrucktwo
Jul 14, 2007 06:11 PM
JRM6868
Mar 2, 2006 08:13 AM
