'63 292 distributor
Old Jun 19, 2019 | 09:35 PM
kd5fvm's Avatar
kd5fvm
'63 292 distributor
so lookin for a ct3f-12127 4dc dizzy.....63 292 f11 4x4..... thanks for any help....
Old Jun 20, 2019 | 01:16 PM
Crop Duster's Avatar
Crop Duster
You might try posting in the Y block forum. https://www.ford-trucks.com/forums/forum56/
If you are looking for that exact distributor somebody might have one. What is wrong with the one you have? There are company's that rebuild them and then there is this guy who makes new electronic ones for Y blocks.
Best in Industry Y-Block Distributor cutom built in the USA for your USA Built Ford Y-Block
Old Jun 20, 2019 | 01:29 PM
Tedster9's Avatar
Tedster9
Welcome to FTE
Need to point out, beware, there are some "counterfeit" distributors in the remann system. The Y-block cores dried up, so the rebuilders for a while were using 302 distributors or whatever. The dimensions are "close" tho not correct, that is, the distance from the mounting flange to the bottom of the distributor gear is too short by 1/4" or so. It will work, but it will get chewed up. Normally the distributor gear is located accurately, within .005", it uses the machined mounting pad in the block itself as a thrust surface. If you keep a sharp eye on eBay, every once in a while a NOS or service replacement distributor will turn up. Most any used distributor by now is worn out, they won't work very well.
Old Jun 24, 2019 | 09:24 PM
Srowe's Avatar
Srowe
I think i have one pm me
Old Jun 25, 2019 | 12:19 AM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
Srowe, he’s new, so I believe you need a certain number of posts before you can use the private messaging system?
jamison29
Jul 7, 2018 09:06 AM
cparks
Apr 18, 2009 06:57 PM
eco
Feb 12, 2006 04:54 PM
Kenny
Oct 26, 2002 10:08 AM
78Bill
Sep 8, 2002 03:03 AM
