Cali model?
Old Jun 18, 2019 | 11:33 AM
greg_8507's Avatar
greg_8507
Cali model?
I'm stripping down an old econoline engine to replace the cracked block in my 03. I have some familiarization with California models for 99.5-03. I was not aware there was such a model for the OBS, but I found a pulse damper on the fuel lines coming off of the pump, and the fuel line are obviously different! When I looked up this part to see what it was (I was a bit puzzled when I saw this part), it seems to be marketed for CA models only. I have also noticed that there are different part numbers for the EBP tube for CA models and non CA models. Now I don't have a non CA engine sitting directly next to this one to compare side by side, but I don't see how this tube would be any different than the one on my non CA engine. Are there any other differences to look for on this engine?
Old Jun 18, 2019 | 12:22 PM
Hit Man X's Avatar
Hit Man X
I heard they had slightly larger injectors.
Old Jun 18, 2019 | 12:32 PM
knottyrope's Avatar
knottyrope
pulse damper was used on Cali models
I have wondered if it would help a non Cali idle better
pic of one online Accumulator Pulse Damper Chamber 7.3L Diesel Super Duty F6TZ9N163AA
http://www.dieselorings.com/media/ca...r-location.jpg
Old Jun 18, 2019 | 05:23 PM
427 fordman's Avatar
427 fordman
Cali model has split shot 120 cc injectors.
Old Jun 21, 2019 | 09:13 PM
fordpride's Avatar
fordpride
The Cali has split shot AB codes 120cc
Old Jun 23, 2019 | 05:09 PM
Diesel_Brad's Avatar
Diesel_Brad
Yup 30% larger injectors(120cc) vs the 90cc of the 48 state truck. That means 30% more power when tuned. I had 300RWHP out of my tuned cali emissions truck
Old Jun 23, 2019 | 07:59 PM
greg_8507's Avatar
greg_8507
Interesting, I thought 120 cc injectors we're used from 94 till 99.5. but I'm not an obs guy either.
Old Jun 24, 2019 | 11:25 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
IIRC the GPR shunt is different.
other: the PCM, the FPR has a harder spring (I think) b/c the fuel pressure is already high (don't shim the Cali b/c it will wear out your pump way prematurely.
Old Jun 24, 2019 | 11:44 AM
Hit Man X's Avatar
Hit Man X
Byron knowns...he is a CA model.
calidiesel
Aug 19, 2018 11:40 PM
dieselsanddogs
Mar 4, 2011 08:37 AM
dieselsanddogs
Mar 3, 2011 08:31 PM
CriticalMass
Apr 10, 2010 12:12 PM
ffdemoss
6.4L Power Stroke Diesel
Jun 12, 2007 07:51 AM
