EGR issue's. Need help!
Old Jun 18, 2019 | 09:08 AM
ldapprich's Avatar
ldapprich
Trailering
I can’t seem to find any post with my same problem. I started having a weird sputtering, at highway speed, in top gear, when I would increase the throttle to the point where it should downshift. Instead of downshifting it would start sputtering and dump large amounts of black smoke. If I pushed the throttle all the way down it would downshift and run fine. This got worse and worse and then I got a egr code. I thought great, I finally found out what was going on and cleaned the egr and then ordered a new one since I didn’t see anything wrong with the old one. It wasn’t clogged or gummy, Just sooty. By this point the problem had got worse. Trying to get it to downshift was very hard and every time I did it looked like I was dumping a gallon of diesel through the engine with the black smoke trail I was leaving. I end up unplugging the egr valve and the truck runs perfect except the idiot light on, which is just the egr codes.
I get the new egr installed and now the problem is different. It doesn’t do the sputtering but the exhaust gas temp runs up to 1400 with a highway downshift and my oil/coolant temp is running up to 20deg different and still a lot of black smoke. All the temps are on the high side. I live in the hills and I can’t drive it normal anywhere and that’s with running no load at all. I didn’t even try hooking the trailer up to it.
I unplug the egr and poof, the truck runs great and tows a 22' car hauler fine!
Does anyone have a clue what is going on???
I have a insight edge programmer with the tow program running. A 5” no cat exhaust. Partially clogged oil cooler with a normal 8 deg differential between oil temp and coolant temp.
Thanks for any help in advance!
Old Jun 18, 2019 | 09:21 AM
bismic's Avatar
bismic
Download ForScan Lite, buy the appropriate OBDII ELM327 adapter and scan for codes.
Old Jun 18, 2019 | 09:29 AM
ldapprich's Avatar
ldapprich
Trailering
The Edge insight reads codes. It's always worked fine before. The only codes I get is when I have the egr unplugged. When I have the egr plugged in I get no codes.
Old Jun 18, 2019 | 09:31 AM
bismic's Avatar
bismic
The Edge doesn't read all the codes. Neither does the ScanGaugeII. The Torque Pro is better, but not as thorough as ForScan.
Old Jun 18, 2019 | 09:37 AM
ldapprich's Avatar
ldapprich
Trailering
Didn't know that. I have a OBDII ELM327 adaptor and TOAD on a laptop. I'l have to download ForScan and try that. It's been a couple years since I looked for OBDII software. TOAD has always worked pretty good on my other vehicles, do you know if it reads all of them?
Thanks
Old Jun 18, 2019 | 09:47 AM
bismic's Avatar
bismic
Don't know about TOAD.
I am hoping you have an EGR valve failure code.
Old Jun 18, 2019 | 09:52 AM
ldapprich's Avatar
ldapprich
Trailering
I had one code that first time before I replaced it. I don't remember what it was. Now I just have the new egr valve installed and unplugged. I'll get the software and check for any other codes in the next couple of days and check back in.
Thanks
Old Jun 18, 2019 | 10:06 AM
bismic's Avatar
bismic
Could very well be injector related also.
What year truck?
Old Jun 18, 2019 | 10:09 AM
ldapprich's Avatar
ldapprich
Trailering
It's a 2006. The weird thing is that it runs just fine with the egr unplugged.
Old Jun 18, 2019 | 03:06 PM
wiredgeorge's Avatar
wiredgeorge
You might mention the actual codes; if the EGR is not there, you would get P0403 and P0405.
Old Jun 19, 2019 | 07:57 PM
ldapprich's Avatar
ldapprich
Trailering
OK, I got P0403-E0, P0405-E0 and P0403-C with the Forscan also got a weird U1900-30 from the ABS module.
I Got P0403 and P0405 from TOAD SCAN
And I got the same from the Edge Insight.
Pretty sure the ABS U1900 is non related.
Any Ideas??
Thanks
Old Jun 19, 2019 | 09:51 PM
wiredgeorge
Had the P0403/P0405 when I bought the truck. The PO had gutted the EGR valve and stuck it back in and through he had done an EGR delete. I subsequently had to do the job properly and get rid of the codes. I had a code that indicated the right ABS speed sensor was acting up and the CAN bus code. Turned out the ABS module was actually in need of replacement. Got a used one cheap and had it reprogrammed and the errors didn't come back. Took quite a bit of trouble shooting as my first indication was to change the ABS speed sensor but that wasn't the problem at all. The old ABS module had a bit of fried electronics inside; probably some water I am guess got in and damaged the thing. Others have found the ABS errors bad connections more frequently.
1bad04
Jan 4, 2012 05:38 AM
j4henry
Jun 10, 2011 02:08 PM
gearloose1
Jun 11, 2010 08:15 PM
hdwilly
1978 - 1996 Big Bronco
Apr 18, 2006 02:53 PM
