Scangauge EGR Question
Old Jan 3, 2012 | 02:36 PM
1bad04's Avatar
1bad04
Will I need to load all three EGR x-gauge codes for you guys to be able to critique for trucks performance? I tied the first one on there website named EVM but it is not working?
Old Jan 3, 2012 | 03:04 PM
phantomphixer's Avatar
phantomphixer
Xgauge/Scangauge
Use this link. Go to Ford 6.0 specific coding.
Ford Specific XGauges : Linear Logic : Home of the ScanGauge
You'll need :
Eng oil temp EOT
Eng Coolant temp ECT
Turbo boost BST
FICM Main Power FCM
Post back here what your deltas are. Difference in oil and water temp after driving 15/20 mins hwy and they should be no more than 15deg split, per Ford.
Old Jan 3, 2012 | 03:40 PM
1bad04's Avatar
1bad04
You'll need :
Eng oil temp EOT
Turbo boost BST
FICM Main Power FCM
THANKS but I all ready have the above gauges you listed working. my question is on the http://www.scangauge.com/support/x-g...ific-xgauges/e there are there different EGR valve gauge codes. I have tried to load the first one on the list but it will not read my egr. Just wondering if the next two codes below it will be sufficient info from the EGR for techs to read?
Old Jan 3, 2012 | 09:58 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
I tried a couple EGR codes and couldn't get them to work. I just wrote it off as some 04s wont through a code when you unplug the thing. So I just quit thinking about it.
Old Jan 3, 2012 | 11:27 PM
VQT's Avatar
VQT
I just purchased a 04 Excursion 6.0L Power Stroke, and got my Scanguage II a few days ago, so far I can't program these functions
- CTQ/Torque into torque converter, do like to know the value of torque generate from the 6.0 L
- CHT/Cylinder Head Temperature, do we need this value?
- IA2/Intake Air temperature - From Bismic spreadsheet this value is the same as MAT, I got MAT value so no problem.
There isn't "Eng Coolant temp ECT", is it the same as *WT pre-program from Scangauge II?
Thanks
Old Jan 4, 2012 | 05:38 AM
wulfman's Avatar
wulfman
VQT yes the WFT is coolant temp you can change the name or just leave it i did.
ibangemup
Jul 17, 2018 03:48 PM
wvmike
Modular V10 (6.8l)
Oct 9, 2008 11:26 AM
hdwilly
1978 - 1996 Big Bronco
Apr 18, 2006 02:53 PM
mudbone1979
Bronco II
Dec 12, 2004 11:40 AM
