C6 drums
My trans guy has disassembled and verified that it has what he calls 'small drums', and says I should use 'big drums' for my 460 application.
I have a FE/390 C6 in the truck now I would rather sell in functional condition with the 390 as a package. He thinks the FE C6 would have the large drums and could be used in the 351m/400 case I have.
Looking at diagrams I see there is a 'forward drum' and an 'direct drum' each with there own clutch packs. It appears that the 'direct drum' that can hold 5 clutches is available from a few places for about $80. Wondering if this is an option, or do I still need the larger forward drum as well...
He said the difference is in the location of the retainer clip that allow more or thicker clutches. So maybe small and big aren't really the right descriptive words.
Builder also states that the 351m/400 case has a smaller reverse clutch that can cause chatter in reverse with big tires (40s). Anyone have an experience to share?
Trying to educated myself so I can make the right decisions, thanks.
What he means in a larger drum is the amount of clutches the drum can hold, larger drum will hold more clutches. The drum is the exact same size between the large and small just the snap ring groove is moved up to allow another clutch.
I would change the drums if it was my truck.
The low reverse clutch has a pressure plate that comes in two sizes, the thinner one will give you a extra clutch, so maybe that's what he is meaning with the size of the reverse clutch.
Make sure he updates and or replaces the low reverse sprag assembly too, use the one with the plastic cage for the E40D/4R100.
disclaimer, old memories could be incorrect.
