C6 forward clutch assembly
When I took it apart, I did my best to keep all the pieces in order but things took longer than expected and crap happens. I have identified all the parts with one exception. I have looked through the great posts on here ... some with pictures even. I have the Haynes manual and referenced a few shop manuals ... so now I am turning to the experts. I have two beveled steel plates for the forward clutch drum. The drawings say that one should be next to the beveled spring but the one outside of the clutches should be flat. I have read some on upgrades and garage adjustments for making the transmission act differently. This doesn't seem to be one of them. Did I mix up the steels without knowing and this second beveled plate belongs somewhere else? Or is this a previous owner's attempt to improve performance. I have found another core C6 which has the flat plate where I need it and quick look shows that it only has the one beveled plate.
Any help would be appreciated.
I would reuse it like that if it was me, I have never seen it to cause a problem and it does get you one more clutch.
If the beveled plate is used in the direct clutch to gain the extra clutch and steel there might clearance issues with the forward drum.
So just to get things straight .. the extra clutch makes the engagement more solid? And does that go bevel side into to clutch pack? or flat against the clutch and bevel out?
And then I take it we can add clutches until we see the right clearance?
Again, thank you for your help.
Adding a extra clutch and steel increases the surface area of the frictions, like wider tires has more traction and reduces the chances of slipping.
The clutch pack can be adjusted with thick and thin steels
