Hard shift & clunk when shifting to REVERSE
Old Dec 19, 2012 | 08:21 PM
351kidd's Avatar
351kidd
Exclamation Hard shift & clunk when shifting to REVERSE
I just recently bought a 95 F150 with a 351. The truck has high mileage, about 190k, and I am not sure how long the transmission has left. It rides smooth down the road, but when I put the truck into reverse it hesitates for a moment then makes a loud clunking sound(as if a door is being slammed) and then jerks into gear. The reverse works great at the moment though. Should I be worried, is there anything I can do to fix this?
Old Dec 20, 2012 | 09:05 AM
Lazy K's Avatar
Lazy K
Check the driveshaft universal joints, the motor mounts and trans mount.
Old Dec 20, 2012 | 09:06 AM
Autofair Truck Parts's Avatar
Former Vendor
shift selenoid ? had the same problem in my old 94 F150 302
Old Dec 20, 2012 | 09:26 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Shift solenoids are not used in reverse.
Old Dec 20, 2012 | 09:29 AM
Former Vendor
I had the same problem in reverse, doing into drive, and shifting from 1-2 gears. And when it shifted it would Kick hard!
Old Dec 29, 2012 | 04:11 AM
Ken Blythen's Avatar
Ken Blythen
Is it a C6?
I had one that did this too - a bottle of Lubegard fixed it over 2-3 months.
Reverse operates at double the pressures of the forward gears, & I understand there is a valve that reduces this pressure, momentarily, as you engage reverse.
Mine was not working properly/sticking, but fortunately the Lubegard saved the day.
Old Jan 1, 2013 | 02:07 AM
351kidd's Avatar
351kidd
How do I check if it is a C6?
Old Jan 1, 2013 | 07:52 AM
Mark Kovalsky
How many times does it shift? A C6 will shift 1-2 and 2-3. It could also be an E4OD, which will shift 1-2, 2-3, lock the torque converter, and then shift 3-4.
Old Jan 1, 2013 | 10:26 AM
stuart1's Avatar
stuart1
C6 has a modulator on the rear of the case.
Old Jan 6, 2013 | 04:52 PM
351kidd's Avatar
351kidd
I believe it is a C6. It does shift hard on occasion going from 1-2. Would lubeguard or something like Lucas help solve the problem?
Old Jan 27, 2013 | 10:49 PM
Cheggie's Avatar
Cheggie
This sounds like wear or slop in the driveline, not wear in the transmission. I would look at the u-joints, carrier bearing if equipped, or excess play in the rear end. The 8.8 is a fine rear end, but they do not last forever without a little attention. Check the simple parts first, but do not overlook the possibility of a worn out rear end.
Old Feb 11, 2013 | 02:31 PM
fasthauler's Avatar
fasthauler
Jack one rear wheel up off of the ground and put a jackstand under the axle. Put the tranny in park with the emergency brake off. Rock the jacked up wheel back and forth and see if you hear the clunking. If you do then you have a driveline problem, not a transmission problem. You can further diagnose the problem by crawling under the truck and have some one move the tire back and forth while you are looking to see where the noise is coming from or for any apparent slop in the rear end, yokes, u-joints, etc.
Old May 21, 2019 | 04:11 PM
mark lazicky's Avatar
mark lazicky
4wd Low
I know this is a dead thread... but I'm having a very similar problem with many troublesshooting attempts with no success..
I have a 94 F250 with an EDO4 at 137k. Tranny was rebuilt at 111k... over 10 years aho. She was a grandpa daily for years. Super clean.
I've changed all the sensors that were throwing codes, new tranny fluid and filter, new u joint, and now I'm down to the rear diff.
I'm waiting on a gasket and will be opening her up soon. Perhaps a rebuild kit along with the new fluid, but really just to get a look inside. Not sure if she was ever changed.
I'll try some Lucas transmission fix and see how it goes, but I'm starting to believe it's a drive train issue.
I'll jack her up to and listen for clunks and hopefully pin point and update, but at this point.. any other ideas?
Old May 21, 2019 | 05:18 PM
Mark Kovalsky
Are the codes still there? Most E4OD problems can be diagnosed with the codes.
Old May 21, 2019 | 10:02 PM
fasthauler's Avatar
fasthauler
A lot can be found by just jacking up one rear wheel and yanking it back and forth looking for the area where the clanking is coming from.
