front end identification
Old Jun 17, 2019 | 04:42 PM
jjriley97's Avatar
jjriley97
Is there anything that will allow me to quickly identify what front end is under my truck? The truck is a 65 and it had a front disc conversion done. The tie rod ends are trashed.
Old Jun 17, 2019 | 05:43 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If the parts were swapped from a 1973/79 F100 2WD or 1975/79 F150 2WD and the spindles were changed, there will be ID numbers stamped on them.
1973/74 spindles different from 1975/79 spindles.
1973/74: D3TA-3107-CD or DD Right & D3TA-3108-CD or DD Left.
1975/79: D5TA-3107-HA Right & D5TA-3108-HA Left.
Old Jun 17, 2019 | 11:49 PM
cosmofennema's Avatar
cosmofennema
A photo of the inside wheel area may help determine if it's a Ford parts swap, or an aftermarket disc swap, which usually uses GM calipers.
Cosmo
Old Jun 18, 2019 | 07:36 AM
jjriley97's Avatar
jjriley97
Thank you guys. I'm suspecting that they are from the 73-79 era and I will verify the part numbers. No aftermarket or non-Ford on this one. There are still factory ibeams under there. Do people usually swap them or just the spindles? When you swap the spindles, do you also have to swap the tie rod ends? Dad added power steering to this truck so I suspect it all came off of the same donor, but there is no telling for sure.
Old Jun 24, 2019 | 07:17 AM
jjriley97's Avatar
jjriley97
The assembly is from a 73-74. I was able to locate the parts needed and just have to order them now. Thank you all.
ReyTs66Ford
May 16, 2023 09:00 PM
4drocket
Apr 19, 2019 03:06 AM
BushyTea
May 12, 2015 06:33 PM
grm61
Mar 28, 2010 06:10 PM
rhetor
Dec 29, 2009 04:41 PM
