Help Identifying I-Beams
Old May 12, 2015 | 06:05 PM
BushyTea's Avatar
BushyTea
I have got my C6 trans swap underway and in the truck so I am looking at some other parts that I want to swap/replace such as power steering, brakes and rotors.
When I bought the truck many years ago it already had a disk brake swap done to it so I have no idea what parts were used. Below are the part numbers I found on the I-Beams.
D2TA-8-DA 20 AND D2TA-9-DA
I do eventually plan on going with the DJM drop I-Beams so I can go with the correct 70's model then. For now though, I am wanting to try and run with what is on the truck.
Thanks in advance,
Mike
Old May 12, 2015 | 06:33 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Below are the ID engineering numbers I found on the I-Beams.
D2TA-8 (3008)-DA & D2TA-9 (3009)-DA
D2TZ-3006-C Right & D2TZ-3007-C Left = Applications below & 1973/74: F100 & E100/200 & F250 w/single piston caliber disc brakes (1973/79 parts catalog).
jjriley97
Jun 24, 2019 07:17 AM
rhetor
Dec 29, 2009 04:41 PM
johnnydmetal
Sep 10, 2005 08:40 PM
