Brake Fluid Level Low!!
Old Jul 15, 2019 | 02:40 PM
GlueGuy's Avatar
GlueGuy
I would add that this is a pretty unusual problem. In fact, I've never seen a brake fluid leak that was not external. Sure sounds like a bad issue.
Old Jul 16, 2019 | 03:20 PM
aerocolorado's Avatar
aerocolorado
Originally Posted by GABAR
Unfortunately, any and all parts on any vehicle can fail at any time and the way Murphys Law works, those failures always happen after the manufacturers warranty has expired.
In theory yes, in real world experience these braking systems are time tested modalities and are engineered and built to last for years and years. Modern vehicles have redundant brake systems with the front and rear systems operating independently in case of failure of one or the other. When both systems fail and truck is only three years old AND this issue has seen a recall on F150's up to 2015 there should be some alarm bells going off in Fordland USA. Instead only crickets are heard from Ford corporate headquarters.
Old Jul 16, 2019 | 04:38 PM
GABAR's Avatar
GABAR
Sadly, all auto manufacturers will only issue a TSB whenever enough consumers complain enough and said complaint is brought to the attention of NHTSA and that usually gets the ball rolling.
GunnerAsch
Aug 1, 2019 06:49 PM
barely alive
20
Jan 9, 2019 02:20 PM
cfack
2009 - 2014 F150
15
Jun 25, 2015 08:47 AM
jm5770
Dec 4, 2009 08:58 PM
nickmobile67
Jan 5, 2008 09:58 PM
