Brake booster problem?
Old Jan 5, 2008 | 09:20 AM
nickmobile67's Avatar
nickmobile67
I put a new brake booster on my truck a couple years ago when it started leaking vacuum. The last few days I noticed an intermittent problem. It's like the brake pedal sticks down and the vacuum is holding it. I lift it up and it's fine, but it sure doesn't feel safe. Could the check valve be bad?
Old Jan 5, 2008 | 09:47 AM
moxy123's Avatar
moxy123
Post
Does it stick down with the engine off or vacuum line disconnected?
Old Jan 5, 2008 | 09:04 PM
nickmobile67
It only did it two or three times in the last few days but I've been driving a lot. I think it did do it with the engine off once or twice. And the pedal seemed to go down far. I'm starting to think the master cylinder might be going.
Old Jan 5, 2008 | 09:18 PM
moxy123's Avatar
moxy123
Post
If you are not leaking fluid at the wheel cylinders, lines then it sounds like seals in the master cylinder.
Fluid level good?
Old Jan 5, 2008 | 09:22 PM
nickmobile67
Yea, the first time it did it I checked the master cylinder and it was a little low. I topped it off and it did it one or two more times but the level is still full. Is it safe to drive it another week?
Old Jan 5, 2008 | 09:58 PM
moxy123's Avatar
moxy123
Post
If the back brakes are leaking not too bad, but if it is the front no way.
When it totally fails all you will have is the emergency brakes. Drive slow if you must, but not far.
