Sponsored by: Real Truck
Diff Gear Pattern
Old Aug 27, 2019 | 05:15 PM
  #61
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
It's a limited skip and when I changed lubes a couple of years ago the plug was clean but the grease really needed to be changed.
Denny
Old Aug 27, 2019 | 05:31 PM
  #62
krewat's Avatar
krewat
FTE Leadership Emeritus
Denny
How stiff is it when it moves through that 1/8th of a turn? Consistently loose, or partly loose, and then stiff?
Old Aug 27, 2019 | 05:50 PM
  #63
rvpuller's Avatar
rvpuller
Consistently loose, you can tell it's just the pinion contacting the ring gear.
Denny
Old Aug 27, 2019 | 07:36 PM
  #64
krewat's Avatar
krewat
Between the slop in the pinion-to-ring gear clearance, and the slop from the axle splines to the diff side gears, that does sound like a lot. Time to take the cover off. You knew it was time to change that gear lube anyway
Old Aug 27, 2019 | 08:19 PM
  #65
rvpuller's Avatar
rvpuller
Maybe next year when we are home for the summer, what I was hearing going into gear is gone with the new U joint, changing U joints isn't my most favorite thing to do.
Denny
0markman
21
Apr 6, 2017 09:52 AM
underthebridgejim
15
Jul 16, 2015 09:46 AM
r___r
All Things Towing
18
Oct 13, 2014 01:13 AM
RumRunner78
Jun 9, 2014 08:07 PM
mustange70
Offroad & 4x4
Apr 8, 2007 11:48 AM
