Sponsored by: Real Truck
Diff Gear Pattern
Old Jun 13, 2019 | 08:31 AM
Winstonw's Avatar
Winstonw
Diff Gear Pattern
Let me know what you guys think.
Old Jun 13, 2019 | 09:32 AM
DesertSmoker's Avatar
DesertSmoker
Put more pressure on the yoke/companion flange and pass it around again. Next time don't paint the the whole ring gear just do 3 or 4 4 tooth sections.
Old Jun 13, 2019 | 09:35 AM
Winstonw's Avatar
Winstonw
Ok... let me try that tonight and I will post some more pictures. Thank you!
Old Jun 14, 2019 | 06:47 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
At first glance, it does appear to be off - I see the dial indicator - what's the backlash?
Old Jun 14, 2019 | 06:56 AM
Winstonw's Avatar
Winstonw
Backlash is .006 to .010... Here are some more pictures. Please let me know what you think... Thank you!!
Old Jun 14, 2019 | 07:06 AM
Just Strokin's Avatar
Just Strokin
The pattern looks acceptable to me. Compare to the photos from Yukon Gear installation directions
https://www.yukongear.com/downloads/...structions.pdf
Old Jun 14, 2019 | 07:42 AM
krewat's Avatar
krewat
The pattern should be oval and not flat on one side like your pictures show.
What manufacturer are the ring and pinion set?
Check out the patterns in this article: https://www.pirate4x4.com/tech/billavista/Gear_Setup/
On the concave side of the teeth, the pattern should be nice and oval.
Old Jun 14, 2019 | 07:51 AM
Desert Don's Avatar
Desert Don
My thoughts also. Should be a nice oval shape.
Old Jun 14, 2019 | 07:57 AM
Winstonw's Avatar
Winstonw
"Motive Gear" ring and pinion from East Coast Gear Supply
DANA 60 HP - 4.10R : Motive D60R-410R-MG
Old Jun 17, 2019 | 08:46 AM
Winstonw's Avatar
Winstonw
The pinion looks too deep to me, but I wanted to see what you guys thought. Please let me know... Thanks
Old Jun 17, 2019 | 09:16 AM
DesertSmoker
Yes it is. But you look good on toe to heal location almost dead center.
Old Jun 17, 2019 | 09:21 AM
Desert Don's Avatar
Desert Don
With the pattern being *flat* at the bottom of the valley, I do believe you are correct. Pinion too deep.
Otherwise, looks good
Ha! My fingers are too slow! Somebody else posted while I was typing
Old Jun 17, 2019 | 10:36 AM
Dan V's Avatar
Dan V
As I'm about to under take a gear change on a Dana 60 front, I'm curious as to how you determined the pinion depth. I've read vast amounts of info on this. The current pinion is marked +2...and my new pinion is marked 0.
Dana gears
Old Jun 17, 2019 | 10:42 AM
Desert Don's Avatar
Desert Don
Dana gears
See the links that Larry posted in post #6 and Art posted in post #7 of this thread.
Old Jun 17, 2019 | 10:45 AM
Dan V's Avatar
Dan V
Thanks...have read all of that.
