Brake problems
Old Jun 10, 2019 | 02:57 PM
Don52M3's Avatar
Don52M3
Brake problems
I have a 52 Mercury M3 with a 8.8 rear end and IFS. I’m using a dual master cylinder mounted to the fire wall. I have around 250 miles on the truck and today I could smell my brakes getting hot just running around town at 40mph. My question is has anyone had problem with residual valves sticking and do I need them? They are 2lb.
thanks in advance
Don52m3
Old Jun 10, 2019 | 05:43 PM
CharlieLed's Avatar
CharlieLed
Pressure in the fluid line is only one cause of brakes dragging. Old caliper rubber will get hard and restrict the pads from returning when the brake pressure is relieved. That said, a residual valve is only needed if the master cylinder is BELOW the brake caliper...if your M/C is on the firewall you should not need a residual.
Old Jun 10, 2019 | 06:52 PM
Don52M3's Avatar
Don52M3
Thank, all the pads are new, it’s not a hard drag just enough to heat up the brake and my rims were pretty hot.
thanks again
don52m3
Old Jun 10, 2019 | 08:25 PM
CharlieLed's Avatar
CharlieLed
Don, not usually a pad problem...caliper guide problem. Caliper moves when brakes applied but never fully retract when brakes released. I just went through this exact scenario on a truck I recently bought from a guy who had it parked for years...rubber around guide pins was hard. Not saying that's your problem but it's definitely worth a look.
Old Jun 10, 2019 | 09:09 PM
Don52M3's Avatar
Don52M3
I'll pull the pins tomorrow and put a little grease on them. I had this same problem on my 32 and the grease worked. I'm going to remove the residual valve also if it isn't needed, just something else to give me a problem.
Thanks for the help
Don52M3
Old Jun 11, 2019 | 04:47 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Make sure the master cylinder push rod is not too long. There should be about an 1/8 inch gap between the rod and the M/C. If it is too long, fluid will not return to the M/C after braking and will build up pressure.
Old Jun 11, 2019 | 06:09 AM
Don52M3's Avatar
Don52M3
I had that problem at one point but adjusted it back.
Thanks
Don52M3
Old Jun 11, 2019 | 06:13 AM
GreatNorthWoods
Thanks
Don52M3
Maybe it is still too tight????
Old Jun 11, 2019 | 10:01 AM
Don52M3's Avatar
Don52M3
I took the residual valve out this morning and everything went well on morning drive. I’m still going to lubricant the pin’s.
thanks
Don52M3
Cabledude
Jul 30, 2010 07:10 AM
tibailey
Sep 21, 2007 06:59 PM
Hamberger
Jun 4, 2007 01:33 PM
honkytonk
Dec 18, 2006 11:50 PM
gtripledip
Dec 3, 2006 09:32 AM
