Well I got the capacitors Thursday night. Soldered them in and worked perfectly. Other than I had trouble getting one of the legs to take solder. But after fighting it for several minutes. I didn't want to overheat the capacitor. I got it pretty good. Drove it from Friday until yesterday with no problems. Then this morning when I tried to start it. Same issue. I think I'm going to buy a new ecm. But it was fun trying to fix the old one.
Now I'm dumb as a rock on this stuff. But sounds like to me, you may have issues with wires to and from the ECM? There has to be a reason there blowing? And Would a new ECM not do the same thing?
Just throwing this out there. Hate to see you swap parts, when it could be other issues.
I'm not real sharp on auto electric either. When I heated the solder on the old capacitors, I'm not sure but I think I pulled the tin from the hole is why I had a hard time getting it to take solder. So it was my inexperienced that went wrong.
While it "could" be something with the wiring, this is a long term well known issue with the Ford computers since they did more than cursory things in the early '80's. By the '86 models, as the ECU's aged the capacitors started failing.
The fixes are well documented, and they make a big deal stressing the importance of buying certain brands of known high quality parts to replace the old ones. Sorry I don't remember the brands and model numbers, but the info is out there floating around. Luckily I've never had to do it (yet) but I guess it's like the TFI modules. Not every one failed (never had that lovely experience either) but enough have that it's a known issue over time.
Generally speaking, the original Ford caps were very good quality and lasted many years. But most of the readily available units fail quickly.
I wish I knew which direction to look for the highly recommended numbers, and when you guys were talking about Mouser, that name sounded familiar. But I just don't have the details memorized.
Good luck with the new computer. Hopefully it's not a wiring issue, but that would certainly be worth researching before attaching your expensive new ECU/ECM!
Maybe a crossed ground, bent contact, frayed wire, all of the above kind of thing?
Paul
I wish the truck was a 5 speed. I'd carburete it. I'm certain it has no electrical problems
Have same issue with my 90 4.9, every cold start takes about 4-5 starts, despite proper fuel PSI both key on engine off and on. My FPR was bad, and replaced it, but made zero difference, same with fuel filter, etc. When engine has been started, it's good to go instantly until it sits and gets fully cooled off again, and same issue. It's very reliable otherwise. I've put techron in, new plugs, wires, etc. I've read about it a lot but never found a real resolution yet.
Well these guys here have helped me a bunch with this. I finally broke down and ordered a new ecm last night. I tried to fix mine but I guess I'm not as skilled at soldering as I thought. Lol. It actually worked for a few days and my soldering job failed. But upon ordering an ecm. I found out the the ecm that's is in my truck is actually for a 93 bronco with a 5.8 engine. I called the guy I bought the truck from and he said yes it was out of a wrecked bronco that had been sitting for years. When that didn't fix the issue they started throwing parts at it. So I'm almost positive that the ecm from the bronco was bad also. Will know tomorrow afternoon. Lol.
Well I bought a new ecm. Advanced auto had one on the shelf which I found odd. I went to buy it and it had greasy fingerprints on it and other signs of not being a reman. It looked like a well used core. I brought it to the sales persons attention. He said they usually keep one on the shelf. After a few minutes of him convincing me it was ok,I bought it. I installed it in my truck and it started. Didn't run well. The transmission was acting weird and had absolutely no power. I parked it for a few days and went to start it and it won't start. So now I'm waiting for yet another ecm.
