1978 - 1996 Big Bronco
Starting issue
Old May 28, 2010 | 11:49 AM
phillips91's Avatar
phillips91
Starting issue
I have a 1992 Bronco, 5.0, E4OD tranny and 217k miles that is having trouble starting. About 90% of the time it won't start on the first try. I can hold the ignition in the start position indefinitely and it won't even attempt to fire. It turns over fine, but no fire. On the times it doesn't start right away(within 2-3 seconds), I can turn the key off and try again and it starts immediately 100% of the time. It doesn't matter if it has been sitting over night, just started 5 minutes beforehand, just shut off long enough to fill up with gas, etc. Almost every single time, start it for 2 seconds, turn it off then start it again and it starts. It has brand new plugs, wires, coil, TPS and starter. Anyone have any ideas?
Old May 28, 2010 | 01:21 PM
g_k50's Avatar
g_k50
How's your fuel pressure, might be a Fuel Pressure Regulator, fuel pump issue.
Old May 28, 2010 | 01:29 PM
phillips91's Avatar
phillips91
Brand new fuel pressure regulator too. Fuel pressure was good when I checked it, but I have no idea how old the fuel pump is. I can always hear the fuel pump when I turn the key on, so I know it is at least getting power to it.
Old May 28, 2010 | 08:44 PM
g_k50's Avatar
g_k50
Does it start right away if you spray starter fluid in the air box? If so then it's fuel related, if not then it's spark related.
In any event it sounds like it's not that big, you have a solution already.
grischow2
Mar 6, 2017 02:29 PM
GYSOT250
Jan 15, 2017 03:12 PM
DGMFORD
1997 - 2003 F150
19
Jan 13, 2016 06:02 AM
crownb
13
Dec 8, 2013 01:26 PM
jlager
Nov 14, 2012 09:54 AM
