Stalling while starting
Old May 24, 2005 | 08:27 PM
1982fordf100's Avatar
1982fordf100
Im still having a problem when starting my 95 F150 on the front gas tank. It has the 300. When I start it on the rear tank it starts fine. Its only been doing it when the engine is cold. Fuel filter, cap, rotor, plugs wires are only a year old. I cleaned the throttle body too. After it starts and I drive it then there is no problem, it runs great. When I start it when its warm, its fine. I've tried leaving the key on to hear the fuel pump which I can hear then starting it with the same results it stalls or doesn't fire the first time. The second time it usually starts and sometimes you have to give it a bit of gas to keep it going for a few seconds. I thought maybe it was the fuel pump, but won't it be doing it all the time while driving it? Its almost like its not getting enough fuel on start up. I tried fuel injector cleaner too. Should I try and pull codes? I've never done that before. Any help is great thanks, Fred
Old May 25, 2005 | 07:44 AM
handyman43358's Avatar
handyman43358
Check your fuel pump. It might not be carrying enough pressure to prime it on startup. I've had them go bad and only carry 15-20 PSI and the truck wont run at all if its cold. It will run crappy when its warm and cut out.
Old May 25, 2005 | 04:29 PM
1982fordf100
Where can I check my fuel pressure at? Can I get a guage and put it inline between the line and the fuel filter? Thanks Fred
Old May 25, 2005 | 04:45 PM
Popa Tim's Avatar
Popa Tim
You can get a Shrader valve fuel pressure tester at almost any autoparts store. I don't think autozone will 'loan' one but it couldn't hurt to ask if you have a store near you.
Cheers,
Popa Tim
Old May 27, 2005 | 02:44 AM
DOHC330MustangGT's Avatar
DOHC330MustangGT
Mine starts up when cold and stalls, but once it warms up it's fine and you can shut it off and start it right back up no problem. I think on mine it is the idle air valve sticking. I'll get a new one and report back.
Old Nov 18, 2012 | 08:14 PM
Cody Collins's Avatar
Cody Collins
please help
My 82 302 f100 will start then dies when. I really give it gas any ideas
Old Nov 18, 2012 | 08:22 PM
Cody Collins
And a ticking come from motor speeds up when I give it gas
94GreenTruck
May 23, 2014 09:27 AM
sleazytiki
16
May 16, 2014 09:44 AM
jamesonblade
Aerostar
Nov 15, 2012 12:10 AM
dangerranger10
1983 - 2012 Ranger & B-Series
16
Mar 15, 2010 08:44 AM
72F250390
16
Jul 15, 2005 05:20 AM
