Cooling system issues. Please help.
Old Jun 23, 2019 | 02:37 PM
89straight6ford's Avatar
89straight6ford
I just bought a 1991 F-150 with the 4.9, RWD, E4OD. When I first got it, it would overheat. Ok, flushed cooling system a couple times and put in new thermostat/thermostat housing, and coolant temp sensor. Still running too hot. Installed brand new radiator. Now the issue i'm having is while driving, the truck runs reeal cool, needle stays around the "N" on normal. When stopped, The temperature will rise around a little over the middle, which makes me nervous, remembering the time it overheated. Just installed another new thermostat thinking it was stuck open. Still doing the same thing, while driving the gauge is pegged around the "N" on normal, when stopped it rises a little over the middle mark. I don't know what else to do at this point if anyone can help, I believe the truck is running too cool and not sure why my temp goes up at stops. Any suggestions are seriously appreciated as this is a much loved daily driver that I want to keep running well.
Old Jun 23, 2019 | 02:53 PM
Veltech's Avatar
Veltech
I would verify what temps really are. Hooked up scanner cause mine does similiar. N is 190 and and the m is about 210. So it's in a good operating range on mine, even though I dont like the needle moving that much.
Old Jun 23, 2019 | 05:24 PM
88n94's Avatar
88n94
I think you are okay running on the N. When it goes up just sitting, I would suspect coupling on the fan behind your radiator. Also, is your fan shroud in place?
Macs1964F100
25
May 21, 2014 04:29 PM
Podds
Jun 2, 2013 07:28 PM
Blackwaterforge
15
Jul 14, 2010 10:04 AM
restoringmy46
27
Jun 26, 2008 11:23 PM
broncoray
Jan 18, 2004 06:19 PM
