Help!
Old Jun 9, 2019 | 09:54 AM
Dlatty's Avatar
Dlatty
Help!
I changed my AIR FILTER and now, surprise, it won’t start. Is this a thing?
plugged both sensors back in. I did disconnect the hose that runs from the resovoir to the radiator as well as the battery
Old Jun 9, 2019 | 11:49 AM
Visurveyor's Avatar
Visurveyor
Do you have a code reader. It would help the guys here to see what your readings are.
Icp
Ipr
Ipr duty cycle
FICM Voltage
Ficm power
Therse is a long list. You would be good to get and obd11 Bluetooth dongle and download Forscan lite to your mobile device. 30 40 dollars all together. It is the best out there right now for reading codes on a 6.0.
Old Jun 9, 2019 | 01:42 PM
bismic's Avatar
bismic
Also .... will the engine crank? If so, what rpms will it achieve when cranking?
Old Jun 9, 2019 | 03:52 PM
BLADE35's Avatar
BLADE35
Are the battery cable tight clean
Old Jun 10, 2019 | 05:51 AM
Yahiko's Avatar
Yahiko
One other point on the battery connections.
Did you remove the wire that taps the main power?
Here is the Power Distribution Diagram. I also
gave you the relay and fuse PDF. Both of these
are for the 2004 year.
BakedPotato65
Electrical Systems/Wiring
May 16, 2026 06:38 AM
nddragon01
2004 - 2008 F150
Mar 14, 2024 03:29 PM
GreaseGun Joe
May 30, 2021 08:01 AM
genny76
1983 - 2012 Ranger & B-Series
Mar 4, 2016 12:48 AM
1993 E-150
Jan 10, 2008 08:55 PM
