Driven Gear
Old Jun 14, 2019 | 10:06 AM
  #46
Oilboy34's Avatar
Oilboy34
I called NOS about a week ago when Bill gave me part number and it said they had one....they don't.
Our current gear ending in B-8 looks to be in good shape I just have no idea what it came out of.
C3OZ-17285-C out of Fairlane, would that work? It's on ebay
I believe Bill posted spacer is obsolete somewhere but I can't find it. Is that correct Bill? Maybe with correct part number I can find some specs. If not I will try calipers and having one made.
Old Jun 14, 2019 | 10:08 AM
  #47
Oilboy34's Avatar
Oilboy34
Old Jun 14, 2019 | 12:32 PM
  #48
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
8J-17288 .. Spacer - Speedometer DRIVE Gear / Obsolete
No one has any.
C5TZ-17285-C is an 8T Steel DRIVE gear
C3OZ-17285-C This might work, it's a 7T steel DRIVE gear.
7 available NOS
Old Jun 18, 2019 | 09:43 AM
  #49
Oilboy34's Avatar
Oilboy34
Could not find the spacer as Bill said.
I found on Amazon a steel shim kit with inside diameter of 1 3/8" and 1 7/8 od. It comes in 19 different thicknesses. Couple different reviews said they used in transmissions and worked great so I will let everyone know.
Old Jun 19, 2019 | 08:09 PM
  #50
BobbyFord's Avatar
BobbyFord
Good luck, bud.
Old Jul 25, 2019 | 09:22 AM
  #51
Oilboy34's Avatar
Oilboy34
[QUOTE=Our current gear ending in B-8 looks to be in good shape I just have no idea what it came out of.
C3OZ-17285-C out of Fairlane, would that work? It's on ebay.[/QUOTE]
Had time to get truck on hoist yesterday. We experimented with Fairlane drive gear that we bought off ebay for just a minute. The problem was the outer diameter of it. The inside diameter was perfect but it had a larger outside diameter. This wouldn't allow the driven gear to seat properly.
We then used the steel shim spacers we bought off Amazon to get the "play" out of drive gear that was already in truck. The two also put the driven gear centered over the drive gear.
Driving truck after re-assembly the speedometer worked nice and smooth. Now we will see if it stands the test of time.
Old Jun 20, 2021 | 09:23 AM
  #52
Oilboy34's Avatar
Oilboy34
Well the driven gear didn't stand the test of time. Last night speedometer started jumping around and clicking. As Cosmofennema said on another thread, if you don't replace the drive gear you might as well buy a bunch of the driven gear as it will continue to apple core them. This appears to be the case!
So, since the Drive Gear is obsolete per NumberDummy I have to think outside the box and come up with something compatible. So what I'm wondering, Is the tailshaft the same diameter on a cruise-o-matic no matter if it went in a galaxy/mustang/thunderbird etc? If that is the case would one of their drive gears work if they are 8 tooth?
My current drive/driven gear setup was reading about 10mph slower than I was actually going, could the driven gear be upped to a 20 tooth?
Some of those other cars drive gears appear plastic, and my driven gear is supposed to be steel, see any issues there?
Old Jun 20, 2021 | 12:04 PM
  #53
Crop Duster's Avatar
Crop Duster
You can try these guys. They probably don't have anything, but you never know. Performance Transmissions and Parts for GM, Ford, Dodge from PATC (transmissioncenter.net)
Scotty's 52 F3
15
Apr 3, 2020 03:31 PM
Gary Lewis
26
May 3, 2016 09:41 PM
AUCoop94
Sep 22, 2014 12:15 PM
davewave649
Aug 27, 2012 12:14 PM
jimi
Nov 19, 2008 02:17 AM
