Driven Gear
Old Aug 27, 2012 | 02:28 AM
davewave649's Avatar
davewave649
Driven Gear
Ok so i pulled my driven gear so I could figure out what gear I need to correct how the speedo reads. Right now it seems to be off 1 mph for every 10 so when it reads 60 im actually doing 66 according to my phone gps. So heres what I found. its a 20T gear and looks like this:
I have no clue how to find what gear i need so any help is appreciated. Thanks guys!
Old Aug 27, 2012 | 04:14 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
What you have: C1DZ-17271-A .. Black Nylon Speedometer DRIVEN Gear-20 teeth, type 3A = ////
Adding a tooth will slow the speedo down 5-7 MPH: C4OZ-17271-A .. Red Nylon Speedometer DRIVEN Gear-21 teeth, type 3A = ////
16 thru 21 tooth nylon DRIVEN gears have been used since 1960, all are available from Ford/autoparts stores.
Take this gear to the parts store to match it up. Some teeth run this-away: //// some teeth run that-away: \\\\
Make sure when you do the comparo that the shaft is pointing up, as it is now. Otherwise you'll be comparing bassackwards.
If you install a \\\\ DRIVEN gear, the DRIVE gear on the output shaft will chew it up in a NY minute.
Old Aug 27, 2012 | 09:50 AM
66f-100's Avatar
66f-100
One more tooth on the driven gear should do it. Here is a reference program that calculates it for you. You just fill in drive gear, rear end ratio, and tire diameter (which you can easily look up). We should make a sticky note for the program.
Speedometer Calibration Program - Method 1
Old Aug 27, 2012 | 09:59 AM
NumberDummy
None of this jazz is required. Post 2: I already gave the OP the info. His truck has a black 20T nylon driven gear, needs a red 21T nylon driven gear.
What else does he need to know?
Old Aug 27, 2012 | 11:03 AM
davewave649
Thanks for the info Bill and 66. That calculator would be a good thing to have around for future reference
Old Aug 27, 2012 | 11:37 AM
37 Ford guy's Avatar
37 Ford guy
Dave, I have a thumbnail that looks kinda like yours and a finger that looks worse!!
Who needs tattoos when we have our own slick battle scars?
now, back to your speedo gears.....
Old Aug 27, 2012 | 11:44 AM
66f-100's Avatar
66f-100
Bill, I agree with you. I simply posted that program for reference. Someone else may do a search on "driven gear" and it may help them.
Old Aug 27, 2012 | 12:14 PM
davewave649
Hahaha I've got a big ol scar on my forearm and a few others on various fingers that put that thumb to shame!!! It's all part of the fun, each ones got a story lol
gazzy230
Jun 18, 2018 10:37 AM
Shadowrider123
19
Jan 20, 2015 05:56 PM
AUCoop94
Sep 22, 2014 12:15 PM
kevinfelix
22
Aug 1, 2011 03:06 PM
yellow72f100
Nov 2, 2005 06:52 PM
