Lift Spring Companies?!?
Old 06-04-2019, 10:08 AM
Ian Clarke's Avatar
Ian Clarke
Ian Clarke is offline
I have checked out Atlas Springs and I was wondering what other companies are out there?!?
i have a early 77’ 250
Old 06-04-2019, 10:36 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Received 3,409 Likes on 2,530 Posts
Deaver https://deaverspring.com/
Superlift https://superlift.com/ford-lift-kits
Skyjacker https://skyjacker.com/
Jack-it https://www.jackit.com/lift-kits/sus...d-f250-1341937
Rough Country https://www.roughcountry.com/suspens...lift-kits.html
Tuff country https://www.tuffcountry.com/
Rocky Mountain carries Rough Country and Skyjacker and might have free shipping?
Atlas is the only company that even has/offers a option to delete the rear OEM block all together. Even if you get a 6" lift kit (front leaf springs only) from Skyjacker (lift system means new replacement REAR leaf springs) you still have to reuse the OEM block.
Also time to think about factor in $$$ new rubber or poly bushings in your rear shackles. New u bolts, new shocks, longer brake lines. Skyjacker has the 3 steel braided ones. E brake cable drop bracket. Drop pitman arm, (F250?) adjustable steering link.
Your 77 an early one? Like HB early? If so your rear leaf spring are 2 1/4 wide and not like the late 77-79's that are 3". But your front are 3". Also your steering set up (Power Assist., Garrison or Bendix will probably have a different set up as far as what is needed for a lift kit.
Old 06-04-2019, 11:02 AM
Ian Clarke's Avatar
Ian Clarke
Yes, early HB 77’ February 28th build date
Old 06-04-2019, 11:13 AM
Ian Clarke's Avatar
Ian Clarke
I’m looking for a 6” or bigger. Sorry should have stated that earlier. I want to keep my rear blocks so I can have the added lift to clear 38”-40” tires.
Old 06-04-2019, 11:59 AM
77&79F250's Avatar
77&79F250
I am trying to locate a web site that has BIG lifts like 8" and 10". What about a 6' and a 2" body lift? Cheaper way to go.
Skyjackers lift versus tire size. file:///C:/Users/Rich/Downloads/Tire...heel-Chart.pdf
So it says...66-77 F-250 High Boy 4WD 2” 38” 12.5” 16.5-20” 9.75” 3.75”
4” 40” 12.5” 16.5-20” 9.75” 3.75”
Any though of converting to a 78/79 steering set up? High steer or cross over? Also remember that much lift on a HB with a low pinion front D44..... you might need to drop the xfer case a bit and or get new longer d/s.
Old 06-04-2019, 12:17 PM
Ian Clarke's Avatar
Ian Clarke
I’m actually will be installing HP Dana 60 from a 78-79 Ford. I’m aware of the steering changes that will be required.
Old 06-04-2019, 12:51 PM
77&79F250's Avatar
77&79F250
Yea I seen your thread, at least you have a plan and sounds like you are on top of it. Good luck with it. Post up the process.
Old 06-04-2019, 02:32 PM
mark a.'s Avatar
mark a.
mark a. is offline
Now would be the time to change to 3" wide springs in the rear. There are a lot more available in 3" and the ride will be a lot better.
Old 06-05-2019, 06:16 AM
77&79F250's Avatar
77&79F250
Old 06-05-2019, 02:06 PM
buckin69bronco's Avatar
buckin69bronco
buckin69bronco is offline
If you are considering changing the spring hangers you might want to look into going to front and rear 99-04 super duty springs. They come in a huge amount of lift heights/options with more companies selling them than dentside springs.
Old 06-05-2019, 03:51 PM
speedfreak78's Avatar
speedfreak78
speedfreak78 is offline
X2, but If you're going through the work might as well get some 08+ super duty rear springs they're over 10" longer than our stock springs. Better ride, more flex.
Old 06-05-2019, 07:16 PM
SlikWillie's Avatar
SlikWillie
SlikWillie is offline
Generalspring.com
They will make you what ever size lift spring you want. Usually cheaper too. Also, MADE IN AMERICA!!!
Old 06-06-2019, 04:56 AM
maddogjohnson's Avatar
maddogjohnson
maddogjohnson is offline
Originally Posted by SlikWillie
Generalspring.com
That link redirects to tennesseespring.com and I didn't find a page that indicated they do leaf springs. What more can you share about them? Do they only do coil springs?
Old 06-06-2019, 05:13 AM
77&79F250's Avatar
77&79F250
There is a General Spring in Kansas City. https://www.generalspringkc.com/Leaf...ord_s/1860.htm
Old 06-06-2019, 07:54 AM
SlikWillie's Avatar
SlikWillie
That's the one! Thanks, Rich!
mustang81
13
11-26-2019 08:02 AM
kawasakiklx1
05-16-2017 02:12 PM
Lythgoe12
02-06-2016 09:45 PM
aidandj
08-22-2013 07:14 PM
Double AA
09-27-2007 01:28 PM
Quick Reply: Lift Spring Companies?!?
