Lift Spring Companies?!?
I have checked out Atlas Springs and I was wondering what other companies are out there?!?
i have a early 77’ 250 |
Deaver https://deaverspring.com/
Superlift https://superlift.com/ford-lift-kits Skyjacker https://skyjacker.com/ Jack-it https://www.jackit.com/lift-kits/sus...d-f250-1341937 Rough Country https://www.roughcountry.com/suspens...lift-kits.html Tuff country https://www.tuffcountry.com/ Rocky Mountain carries Rough Country and Skyjacker and might have free shipping? Atlas is the only company that even has/offers a option to delete the rear OEM block all together. Even if you get a 6" lift kit (front leaf springs only) from Skyjacker (lift system means new replacement REAR leaf springs) you still have to reuse the OEM block. Also time to think about factor in $$$ new rubber or poly bushings in your rear shackles. New u bolts, new shocks, longer brake lines. Skyjacker has the 3 steel braided ones. E brake cable drop bracket. Drop pitman arm, (F250?) adjustable steering link. Your 77 an early one? Like HB early? If so your rear leaf spring are 2 1/4 wide and not like the late 77-79's that are 3". But your front are 3". Also your steering set up (Power Assist., Garrison or Bendix will probably have a different set up as far as what is needed for a lift kit. |
Yes, early HB 77’ February 28th build date
I’m looking for a 6” or bigger. Sorry should have stated that earlier. I want to keep my rear blocks so I can have the added lift to clear 38”-40” tires.
I am trying to locate a web site that has BIG lifts like 8" and 10". What about a 6' and a 2" body lift? Cheaper way to go.
Skyjackers lift versus tire size. file:///C:/Users/Rich/Downloads/Tire...heel-Chart.pdf So it says...66-77 F-250 High Boy 4WD 2” 38” 12.5” 16.5-20” 9.75” 3.75” 4” 40” 12.5” 16.5-20” 9.75” 3.75” Any though of converting to a 78/79 steering set up? High steer or cross over? Also remember that much lift on a HB with a low pinion front D44..... you might need to drop the xfer case a bit and or get new longer d/s. |
I’m actually will be installing HP Dana 60 from a 78-79 Ford. I’m aware of the steering changes that will be required.
Yea I seen your thread, at least you have a plan and sounds like you are on top of it. Good luck with it. Post up the process.
Now would be the time to change to 3" wide springs in the rear. There are a lot more available in 3" and the ride will be a lot better.
You can get your 3" wide rear leaf spring hangers here. https://www.autoandtrucksprings.com/ford-leaf-springs
And shackles. https://www.autoandtrucksprings.com/...spension-kits/ |
If you are considering changing the spring hangers you might want to look into going to front and rear 99-04 super duty springs. They come in a huge amount of lift heights/options with more companies selling them than dentside springs.
Originally Posted by buckin69bronco
(Post 18691022)
Generalspring.com
They will make you what ever size lift spring you want. Usually cheaper too. Also, MADE IN AMERICA!!! |
Originally Posted by SlikWillie
(Post 18691477)
Generalspring.com
There is a General Spring in Kansas City. https://www.generalspringkc.com/Leaf...ord_s/1860.htm
(Post 18692111)
