Sponsored by: Auxito
Best wheel adapters
Old May 30, 2019 | 06:07 PM
Dixon1948's Avatar
Dixon1948
Best wheel adapters
I need some wheel adapters for my 2003 f150 I want to put some 2018 f150 wheels on it but I cant seem to find any that is an inch and a half thick. I can only find 2 inch thick ones and im scared they will stick out to far and not look right does anyone know where I can get 1 and a half inch thick wheel adapters? Or will the 2 inch thick ones work and look right?
Old May 30, 2019 | 09:40 PM
steve(ill)'s Avatar
steve(ill)
wheel adaptors are not a good idea on a truck that is used to carry a load.... adaptors are for trailer queen cars that go to shows or set and look pretty........... not for trucks.... Do yourself a favor and get good 5 bolt rims made for the 2003.
Old May 31, 2019 | 08:40 AM
IndySilverAnny's Avatar
IndySilverAnny
You realize that you're going from 5 lug, to 6 lug, right? Do they even make any?
Old May 31, 2019 | 02:26 PM
Dixon1948's Avatar
Dixon1948
They make them but I only see them in 2 inch
Old May 31, 2019 | 06:49 PM
00t444e's Avatar
00t444e
As long as they are good quality adapters and installed properly, there is no problem towing or hauling with them. I have had 2" spacers/adapters on my f250 for 2 years, no problems at all.
Old Jun 2, 2019 | 08:02 AM
Dixon1948's Avatar
Dixon1948
We're they original stock rims or aftermarket and if they were aftermarket Did They stick out from the truck or have stock appearance?
Old Jun 2, 2019 | 08:21 AM
00t444e's Avatar
00t444e
They are stock 16x7 wheels with 315/75/16 tires, they stick out a little bit but not to bad. The 4" wider track with also improved stability.
Old Jun 6, 2019 | 06:09 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
It is likely that the adapters are so thick because they need to leave room for the original studs so the (adapted) wheel doesn't touch then.
learpilot
Sep 6, 2009 10:02 AM
bad96
Offroad & 4x4
Feb 1, 2009 01:52 AM
Fifty4F100
Aug 8, 2005 07:32 AM
GreatNorthWoods
Nov 17, 2002 07:58 AM
davidoldfordfan
Jul 6, 2002 11:11 PM
