Trailer 7 pin cable ?
Old Sep 30, 2019 | 08:19 AM
06pghescape's Avatar
06pghescape
Wow , Never would have thought that . Glad i went to the new set up , seems safer more reliable. Thanks
Old Sep 30, 2019 | 12:51 PM
RV_Tech's Avatar
RV_Tech
I always do the same. Cost is negligible, new saves time, and likely will be more reliable than using old cord over.
Old Oct 29, 2019 | 11:23 PM
tanner1998's Avatar
tanner1998
Personaly, I would replace the whole harness. Those wires get old and brittle after a while, and its best not to have problems while you're on the road!
Old Nov 2, 2019 | 11:54 AM
seventyseven250's Avatar
seventyseven250
On the trailers I have torn into, which is only two, those "wire nuts" that look like home-use marrette connectors are actually crimped connectors, and pretty durable. I'm sure they are used for ease of assembly, but they don't seem to be failure prone from what I've heard. I use a good-wuality butt-style crimped connector now that I have a quality crimper.
Old Nov 2, 2019 | 06:02 PM
Ralioth's Avatar
Ralioth
I did replace the entire cable with this : https://www.online-led-store.com/7-w...-accepspwr0087 But haven`t had the trailer out since .
I haven't needed to tear into mine, yet, but did the wiring color coding coming from the trailer into the box match the new box and cable?
Old Nov 2, 2019 | 06:13 PM
06pghescape
Yes it did and on mine they were wire nuts in a metal work box. My buddies son stopped by while we were doing it and helped. He rewires diesel hybrid locomotives for Norfolk Southern and couldn't believe how it was done.
Old Nov 2, 2019 | 07:55 PM
Ralioth's Avatar
Ralioth
That'll make it easier. Thanks!
Old Nov 3, 2019 | 06:11 AM
meborder's Avatar
meborder
The wire color on the harness I bought didn’t match. All the colors were right but none of them were on the right pole.
The box was spot on.
Just double check the harness.
Old Nov 3, 2019 | 07:04 AM
roake's Avatar
roake
I fixed mine with tape and lived to regret and repair anyway. The tape trapped water and accelerated corrosion. The connections became unreliable and had to be cleaned all of the time. At some point, you are going to want to replace.
HRTKD
Jul 8, 2021 10:07 AM
Midnite150
Nov 23, 2020 10:41 AM
MissIndependent
35
Jan 30, 2009 06:48 AM
wmcutter
All Things Towing
Nov 23, 2005 08:48 PM
K2JJB
All Things Towing
Aug 18, 2004 11:03 PM
