Pcm shudder?
Old May 28, 2019 | 10:28 PM
JamesJ4's Avatar
JamesJ4
Originally Posted by torq'ta 5 8
before you throw parts at it, test 4 show how to test PIP
Part 1 -How to Test the Ford Ignition Control Module (Distributor Mounted)
This why I really like this forum, seems like there’s always someone offering great tips/help without making me feel like an idiot for being a novice at this stuff. I’m learning more and more from this site. Thank you for the info, I’ll try it this weekend.
Old May 29, 2019 | 06:50 AM
rla2005's Avatar
rla2005
Originally Posted by Cemoe
as for the water/ arcing—- yes i sprayed water on the sparkplug wires, started the truck and shut the lights off to look for arcing—- then covered any arcs with rubber hose—-( internet thing lol)
Brand new plug wires and you are already experiencing arcing? Throw those things in the trash IMHO.
Be sure you have the plug wires routed to prevent misfire as well.
Spark Plug Wire Routing for '94-up 5.0L & all 5.8L
courtesy of Steve83
Old May 29, 2019 | 07:16 AM
Cemoe's Avatar
Cemoe
Thankyou—- what brand plug wires do you use—/ these are beldons from napa
Old May 29, 2019 | 01:05 PM
rla2005's Avatar
rla2005
I have used Ford Racing plug wires with good results. Others swear by Taylor and other top name brands. Any plug wires that exhibit arcing right out of the box are garbage in my book.
Old Jun 2, 2019 | 06:13 PM
Cemoe's Avatar
Cemoe
Update
Bought chilton manual, haynes digital manual, started reading.
long story short ( bad plug wires)
also timed it with spout out
routed plug wires correctly
best its ever ran
Thanks ALL!
Old Jun 6, 2019 | 01:38 AM
Skitter302's Avatar
Skitter302
1995 f150 5.8 with e4od—— original tranny and torque converter replaced 114,000 miles (napa) —— first tranny had a shudder in d and od on light acceleration ——replaced tranny and within a year shudder is back, also engine is missing——what are the chances the pcm is making this shudder—-(
Congrats on finding a plugwire issue. I just wanted to add my post here.
My PCM in my 1991 went bad and it toasted my solenoid pack. Also made my torque converter do a few funky things. Put in a new PCM and changed the pack and my shutter issues stopped. Here are a few photos of where my capacitors leaked that caused the issue.
Even though your issue wan't the EEC unit its not important not to over look it.
Sbroom
17
Nov 16, 2015 12:20 PM
barnym17
Aug 6, 2013 02:20 PM
LSO1123
23
Aug 5, 2011 11:50 AM
SALVY
Mar 19, 2009 09:31 AM
jalampi
Oct 10, 2002 03:53 PM
