Hello guys, Have some issues regarding Duraspark III, is there a way to check that the Ignition control module is OK, and working properly, and is there also a way to do the same for the EEC III computer under the driver side seat
Cant get the bronco to start, Btw its a 1983 5.8 carbed, with california emission
Most automotive parts stores will check ignition modules for free. You'll have to remove it from the vehicle and bring it down there.
Make sure they run the test about 4 - 5 times to get the module good and hot. A failing module will still work when it's cold.
