66 F-100 352 Charging Problems
Hey all, new poster to the forums, but long time lurker.
My 66 F-100 isn’t charging. I have read through every post I could find. A breakdown of what’s going on and what I’ve done:
At this point the only think that I can think of is that I have a draw somewhere? The battery will hold a charge even sitting for a few months, so it’s not drawing when it’s parked. Any ideas on how to get me up and running would be great!
Thanks!
- I’m getting 12.4 amps at the battery, 11.5 amps with the headlights on.
- I’m getting 12.1 amps at the A terminal on the Voltage Regulator as well.
- I have replaced the alternator with a 70a Tuff Stuff alternator, and Voltage Regulator from summit racing
- I have replaced the Voltage Regulator wiring harness with one from Dennis Carpenter.
Thanks!
I would also check the wiring harness with a multi-meter for continuity on each circuit. I bought a new alternator harness a few years ago for my '69 mach 1 that was made wrong and wouldn't trigger the alternator to charge. Is the ALT light on in the dash? It is a balanced circuit with the battery on one side and the alternator on the other. When it's on that means the battery is powering the light and the alternator is not putting out voltage, which is what it sounds like as you should be getting approx. 14.2 to 14.5 volts at the battery when the engine is running above an idle.
Thanks for the replies everybody. I have checked my wiring on the alternator harness, and it's all correct. I am getting 12v at the alternator. I will check continuity throughout the harness and start hunting elsewhere. Someone else has suggested the ignition switch, and possibly the fusable link coming from the alternator. I will get back to you all with an update!
pinkpantherbeekeeper
05-30-2013 11:29 PM
dobeydude
01-29-2013 08:22 PM
josh390
18
11-08-2008 04:03 PM
