low voltage/battery charging issue
Old Jan 27, 2013 | 03:44 PM
dobeydude's Avatar
dobeydude
I have 77 F250 ranger with a 5.8 modified engine. I installed a new wiring harness from Centech. It has a new battery, alternator and voltage regulator as well. It starts and runs like a champ but the battery isn't getting charged. I had the new alternator and regulator tested and they were good. My voltage gauge stays around 11.5 - 12. but eventually drops and I have to charge the battery. The alternator puts out 15.5v when they tested it, I can only get 12.2 right at the alternator and at the battery why it's running. is this a ground problem? I added a ground from the block to the chassis and that helped a little but the bat keeps dying. Any ideas what my prob could be?
-first time poster here, I've learned a ton from everyone on here! you guys are great!
Old Jan 27, 2013 | 03:53 PM
nine inch rear's Avatar
nine inch rear
First off, clean the surface where you have your voltage regulator mounted. It needs a clean ground surface. Hook up your volt meter on battery charge back wire behind the alternator and ground. Disconnect the voltage regulator plug. Jump "I" terminal to "F" terminal on the plug. Start engine, and check voltage. Only do this for as little time as possible. Your full fielding the alternator, and pumping in 12 volts, where it normally takes 6 volts. If your charging ok, then its your regulator. If your not charging, then its your alternator and or related wiring.
Old Jan 27, 2013 | 03:56 PM
nine inch rear
Also wanted to add, get a jumper wire and clip it from alternator case to battery neg. If you start charging, you have a ground problem
Old Jan 27, 2013 | 03:59 PM
fmc400's Avatar
fmc400
MSEE
Let's make sure the voltage regulator is even getting powered up first. Assuming this truck does not have an ammeter, check the voltage at the wire going to the 'I' terminal of the voltage regulator with the key in RUN. Report your results.
And while you're at it, please describe how you have the alternator and regulator wired up.
Old Jan 29, 2013 | 08:22 PM
dobeydude's Avatar
dobeydude
thanks for the help guys
I ended up taking my truck "JoAnn" into the shop here. The problem was the wire from my voltage regulator to my alternator needed to be spliced and connected to the little screw on the starter solenoid. The VR needed an exciter wire between itself and the alternator. All is good, running at 13.5-14v now!
$65 bill was worth it being done, now I can go Coyote hunting!
Thanks again
~Dustin
BDodson
Apr 5, 2018 05:26 PM
ryank59701
Oct 19, 2015 02:04 PM
fisherm1
Electrical Systems/Wiring
Aug 14, 2008 09:07 AM
custom1106
Apr 11, 2008 09:52 PM
lemcham
Apr 18, 2007 10:10 PM
