P0611 and P1378 codes
Old May 24, 2019 | 12:25 AM
Motohead911's Avatar
Motohead911
I just did a DTC check on my truck and pulled these to codes. I always Monitor my voltage with Torque Pro and the FICM has never dropped below 47v. My batteries check at 12.6v with a volt meter.
Some quick background, I just finished doing work on the truck last weekend. The batteries were d/c'ed for about a week, but I charged them both before starting the truck up again. I did pull the FICM relay while I cranked the motor to prime the oil system. Is it possible these where left over from that? I have not a long or no start situation.
Old May 24, 2019 | 12:39 AM
bismic's Avatar
bismic
Battery checks need to be a load test. Not much help to just check the voltage.
Doesn't hurt to clear the codes and see if they come back.
Old May 24, 2019 | 01:09 AM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
Mark is absolutely on track. If the truck is running fine now, you clear the codes and don't have them come back....I'd say you are in good shape!
Old May 24, 2019 | 12:40 PM
Motohead911
Kind of what I figures, just left from when I cranked with the relay removed. Thought I cleared all the codes at that time, must have missed those. I have since cleared them and so far they haven't returned. Was just checking.
Old May 24, 2019 | 01:05 PM
FICMrepair.com
Former Vendor
It's always nice to dodge a bullet! Glad you are up and running!!
Old May 24, 2019 | 10:24 PM
87crewdually's Avatar
87crewdually
If there's ever a next time..... to crank the engine to prime oil, use the starter trigger wire near the passenger side fender on the firewall by disconnecting it and touching it to the + battery terminal. Then no addition of codes, no cycling of glowplugs for no reason, and no reason to pull relay.
iateatoad
13
Dec 8, 2012 10:35 PM
Jules3084
Jun 13, 2011 11:32 AM
aljen466
Electrical Systems/Wiring
Jan 20, 2009 11:02 AM
kools20
Bronco II
Jul 22, 2008 07:06 PM
duncannon6
Bronco II
Oct 30, 2006 01:23 PM
