FRAME SWAP
Old May 23, 2019 | 10:00 AM
5starCabF-3's Avatar
5starCabF-3
FRAME SWAP
Hey Guys I have a 1994 Ranger 2WD standard cab with a great body but the frame is rusted out. What years of frames will interchange?
Old May 24, 2019 | 08:32 AM
ranger pat's Avatar
ranger pat
Veteran: Navy
1993 thru 1997 have the same frame and body lines.
Old May 24, 2019 | 09:28 AM
5starCabF-3
thanks Joe.
I called a couple wrecking yards and one told me 1993 and 1994 only interchange. I don't understand because I have combined the parts from the various years before and other than engine emissions I haven't noticed much difference.
Old Jun 11, 2019 | 12:45 AM
phoskins's Avatar
phoskins
1993-1997 bodies are essentially identical, barring a few minor details.
1998 and later may have body parts that will interchange, but the whole front of the truck is different, so it would likely require some modifications.
Measure mounting locations. I think later models (2008 & later?) are slightly larger trucks by an inch here or there.
Best bet would be to find a '93-97 with a good frame, good drivetrain, and a bad body.
Old Jun 13, 2019 | 04:49 PM
monckywrench's Avatar
monckywrench
Yards tend to go by official interchange guides to cover their posteriors.
Since you'll be pulling the cab anyway you can get ahead of the game and ****** it now, then take pics and measurements to aid your frame hunt. I enjoy cab and frame swaps because they got me things like my '76 F100 cab on F250 running gear and my K1500 4WD 5.3 under a six-banger cab. I used to do them at a used car lot (building from wrecks is very common) and the only tedious part was wiring harness swaps. With a cheap trim tool kit it's easy to swap interiors.
Old Jun 14, 2019 | 10:41 PM
seagull369's Avatar
seagull369
Is the entire frame wrecked or just the tail end of it (the area where most of the bed sits on)? In case the yards aren't checking for one already, ask them to search '94-'97 b2300 models also.
Old Jun 16, 2019 | 01:57 PM
Phinxter's Avatar
Phinxter
If a 92 would work I'm preparing to scrap mine. cab is too rusted for me fix but the frame is in good shape. Been sitting in my garage for 6 years.time to part with it.
Old Jun 16, 2019 | 06:27 PM
5starCabF-3
Frame
Where are you at? The entire rear section behind the cab, the main rails were flaked through and the cross members are gone.
I have found them available in yards down south but the price and shipping I have been hesitating.
Old Jun 16, 2019 | 06:34 PM
Phinxter's Avatar
Phinxter
Upstate NY. About 30 min north of Albany.
dwhawkins89
May 31, 2019 03:40 PM
fordgt55
Aug 29, 2012 12:42 AM
s10 warrior
Jul 30, 2012 06:02 PM
Hunter1
1978 - 1996 Big Bronco
Aug 21, 2003 04:49 PM
FTE Ken
Jul 25, 2002 02:08 AM
