frame options
Old May 31, 2019 | 05:38 AM
dwhawkins89's Avatar
dwhawkins89
frame options
Are there other body years that have the same frame as 73-79? maybe an 80-83 or a 71? just found mine had a slight bend to it. just curious what bolts under
Old May 31, 2019 | 09:05 AM
speedfreak78's Avatar
speedfreak78
What year /model /2wd or 4wd? There were a few different frames used during those years. I don't think there's any other years that would be a direct "bolt on", you'd probably need to move or fabricate body mounts.
Depending on where and how badly it's bent a good body and frame shop can straighten it. We repaired some pretty mangled frames when I worked in a body shop. If it's not a pretzel, it probably wouldn't cost more than another frame.
Old May 31, 2019 | 09:43 AM
Mr.shift's Avatar
Mr.shift
Probably can get it straightened for a few hundred bucks.
Old May 31, 2019 | 09:49 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1972 and older, 1980 and newer use different frames. Without knowing what your truck is, I cannot tell you what 1973/79 frame is the same.
Old May 31, 2019 | 03:40 PM
caravaggio2000's Avatar
caravaggio2000
Not an answer to your question, but I see at least 1 frame a week on CL for between 50 and 200 bucks. I think mostly from people doing a full CV swap.
closer9
Feb 17, 2010 10:16 PM
danger-ranger
May 21, 2008 10:37 PM
TwoX
Apr 26, 2007 02:37 PM
shortstuffrm
Dec 21, 2006 05:47 PM
FTE Ken
Jul 25, 2002 02:08 AM
