3 sp shift linkage
I took a while but I was finally able to come up with the original part number for this sleeve. 2J-7353-A Found some on ebay for a good price so I bought them.
In the meantime I went ahead and made up my own sleeve so I can at least move the truck around while I wait for the part to arrive sometime next week. Here is my sleeve. Not real pretty to look at and I need to finish the grinding, but it is only temporary. I still need to make the rod, but that will be no problem. Already have the rod stock available. Will post more once I have it completed
Made new linkage rods to the transmission
To figure out how much to remove, I set the tube in place and figured where I wanted the steering wheel to be. Once i had it marked i moved the hole in the tube to its new location keeping the orientation with the shift lever post.
For the actual shifter tube i removed the same amount from it. However i had to take it out of the center of the shaft since both ends were critical.
I inserted a steel rod in the shaft since it is hollow in the middle, and welded it bach together. Again keeping the orientation of the hole and lever pocket
I then reassembled everything. The linkage arms clear the floor so no modifications needed to them. I also inserted a spacer in the bottom of the tube to keep the steering shaft centered in the tube.
I don't have a good pic of the before and after of the column but you can see in these what it looked like originally and now. I removed approx 2" from the column and I had to rotate the gearbox up slightly to keep the correct alignment with the shaft mounting plate.
