battery drain problem + other weird problems
Old May 17, 2019 | 11:43 AM
truckrider814's Avatar
truckrider814
On my 90 f-150 2wd 5.0.
1. When i connect the neg cable(key not even in the truck) the fuel pump kicks on for a couple of seconds. I'm pretty sure that this is my battery drain problem, but i'm not sure where to start looking. I swapped out the PCM from my parts truck and still the same problem.
2. The horn only works when the key is in the off position. I swapped out the horn button just to see and no change.
3. When i tried to run a code test the light wouldn't even come on to show codes or system pass. Sometimes when i turn the key on to start it the light will come on for a few seconds like normal other times it doesn't at all.
4. I think im down to the last option but wanted to ask. Sometimes when i start it or at random down the road, the rpms jump up to 3k and stay unless i put it in gear then it idles down but still high, and will idle high while driving. I replaced the IAC(twice) cleaned the throttle body, made sure the valves weren't sticking. but when i unplug the IAC it will idle almost normally little bit too low. Am I safe to assume that the TPS has gone bad? or is there something else that it could be.
I was hoping that the PCM was going to be the fix for my other problems as well but it seems not.
Old May 17, 2019 | 11:53 AM
Scott Bowmaster's Avatar
Scott Bowmaster
The first 3 problems together, make me think the problem could be in the key cylinder/column/ignition switch. Like the truck thinks the key is in a different position than it actually is. Sounds like the pump is priming soon as power is applied.
Old May 17, 2019 | 12:08 PM
Ddaybc's Avatar
Ddaybc
^^ agreed. Sounds like the issue(s) may be ignition switch related. Perhaps take a look at your switch to check for cracked or broken ignition housing, corrosion etc.
Old May 17, 2019 | 12:44 PM
Exwhyze's Avatar
Exwhyze
A coworker and former mechanic told me that the windshield/cowl can leak on top of the fusebox and cause shorts. If your ignition column switch is working as intended, i'd check your fusebox for signs of corrosion. Good luck!
soundssilver
May 30, 2019 03:56 PM
Skuvas
Jan 12, 2013 06:44 PM
PokerPlayer
Mar 28, 2009 06:29 PM
lumanikus
13
Jun 6, 2008 05:19 PM
supercab4x4dually
1978 - 1996 Big Bronco
Dec 14, 2004 11:25 PM
