Best spark plug wires?
Old May 15, 2019 | 08:10 PM
Gunnerboy's Avatar
Gunnerboy
Got a 351m in a 1981 camper special f250..Edlebrock intake and 1406 carb, 2.75" straight pipe exaust, No emissions junk, 14 deg timing, Right at 19 on the vaccum gauge but still running a little rich..So i bumped the gap up to .050 from .042..Now im looking at wires..more voltage means less wasted fuel. So what are you guys running? Im currently at 10mpg my goal is 13..I got 57 gals of fuel on board id love to see 740 miles before empty.
Old May 17, 2019 | 02:14 AM
FMJ.'s Avatar
FMJ.
This, which is one of many, will cover the plug wires :
https://www.ford-trucks.com/forums/1...lug-wires.html
I doubt that the gap increase and new wires will improve the mpg much.
Something like correcting under inflated tyres would have more effect.
19* vacuum at sea level implies that your dizzy vacuum advance is connected to ported vacuum, which is a waste of time.
Connect it to full manifold, and verify that it actually works.
Initially you should see the 14* increase to +/- 29* and the 19'' vacuum increase to +/- 21''.
You'll also see the idle rpm's increase, and simply needs adjusting down.
A vacuum advance that doesn't work ruins fuel consumption.
Old May 17, 2019 | 09:11 AM
Tedster9's Avatar
Tedster9
Careful increasing plug gap beyond spec. Wider plug gaps does increase the firing voltage, but it also increases wear and tear or strain on the ignition system components. Coil will run hotter. Can run into misfire or arcing at high RPM or under heavy load. If the fuel mixture is excessively rich, the carburetor probably needs adjusting i.e. jetting. Lean mixtures are harder to ignite but the stock OEM plug gap should already have this factored.
Old May 17, 2019 | 09:16 AM
Tedster9's Avatar
Tedster9
I think I know what you're getting at, a mechanic's vacuum gauge is always connected to manifold, but for clarity, doesn't have anything to do with vacuum advance. A steady needle of 19" at sea level at factory idle RPM of 500 to 600 RPM is a healthy motor.
For the money, Motorcraft wires are excellent.
Old May 17, 2019 | 09:17 AM
Gunnerboy's Avatar
Gunnerboy
I changed specs to a Non emissions engine..sticker and truck used to be a emissions based engine but not one single component of that stuff remains.. 0.48-0.52 and 14deg timing is what i found for non emissions 351m's was i wrong? Truck runs alot smoother now with the better gap..and im noticing less raw fuel odor.
Old May 17, 2019 | 09:42 AM
FMJ.'s Avatar
FMJ.
Hi there Ted,
I normally specify rpms, but this time it slipped my mind. Oops !
Yes, 19'' @ 600 rpms would be healthy indeed, and would probably be 21'' @ 800 rpms, if connected to full manifold.
I should have asked !
What I was actually getting at, was that when connected to ported, and a vacuum reading is observed, one might not be able to tell if the vacuum advance is actually working.
But, if connected to full manifold, one can see at a glance.
I had diaphragms repeatedly fail on a brand new Pertronix dizzy which I realised immediately. (Gotta permanent vacuum gauge in the cockpit.)
BUT !
The fuel economy went for a ball of sh$t while I waited on each new diaphragm.
You follow that ?
Old May 17, 2019 | 09:50 AM
Tedster9's Avatar
Tedster9
OK, if it's built for it - you are good to go, that's what you want.
Old May 17, 2019 | 09:52 AM
Tedster9's Avatar
Tedster9
BUT !
You follow that ?
Yep. Did you ever get a read on the actual MPG loss, or percentage? I've read 20%, or 2 to 3 MPG on older V8. More?
Old May 17, 2019 | 10:32 AM
FMJ.'s Avatar
FMJ.
I certainly did !!
It dropped from 14 mpg to 11 mpg.
Funnily enough, I never read about it, but yes, it was similar to your figures posted (21% and 3 mpg).
My driving habits etc remained constant throughout.
I probably would have wondered WTF if the vac advance had been ported connected.
And to continue with the hijack, I returned 2 brand new dizzies to Pertronix and one to MSD.
The first Pertronix one had a faulty curve that could not be dialled in, same for the MSD one.
The second Pertronix one must have used weird quality diaphragms.
Pertronix' customer service was excellent. MSD's was crap.
Having realised that the 'big name' brands were hit and miss, I bought a $50 HEI dizzy, which so far has been perfect. (Makes up for the bad gas consumption. LOL)
Old May 17, 2019 | 10:47 AM
Gunnerboy's Avatar
Gunnerboy
The more i can learn the better , ill try full vaccum on my distributor, see if it runs better.
Old May 17, 2019 | 01:16 PM
FMJ.'s Avatar
FMJ.
Good man !
Post up your results/observations as you go along.
When you drive with full manifold vac adv connected, you won't feel a 300 HP to 400 HP change (if you know what I mean), but you might feel subtle changes.
When you get new plug leads, look at the manufacturer comments about resistance in the leads, measure yours with a multimeter, and compare.
Old May 17, 2019 | 01:19 PM
Gunnerboy's Avatar
Gunnerboy
Yes i just swapped it over and re adjusted its holding 20-21hg now , i plam on getting ohms readings on the new wires so i can see how much gain i should get.
Old May 17, 2019 | 02:54 PM
FMJ.'s Avatar
FMJ.
That was quick !
Ok, that cheap, quick, and easy change was simply testing that the vac adv works, and it does.
Drive around a bit with full manifold, then decide between that and ported which one you prefer.
There'll be little to no change to fuel consumption.
The ohms test is purely to ensure the quality of the leads.
No idea how to get from 10 mpg to 13 mpg without knowing a lot more about the vehicle specs and driving habits.
For example, I get 14 mpg with a 50/50 combination of 90 mph cruising with no overdrive, and around town driving, in an F350 dually.
It could do better and it could do worse.
Old May 17, 2019 | 04:30 PM
Tedster9's Avatar
Tedster9
Problem is pickup aerodynamics are not good, and trucks are heavy, and 250s more than some.
If you know someone who has an ignition analyzer scope, they are very useful at looking at the overall ignition health. Some repair shops have one. If you look on that auction site, right now there is a Heathkit for under a hundred bucks, includes all the wiring probes + manuals. I paid $40 for mine, they take a little learning curve but they are REALLY good at exposing ignition defects. You'll need a good HOT spark, good grounds.
High voltage is really weird stuff, everything has to work together as a total package, inside the cap, rotor, plug wire, rotor gap, plug gap, coil resistance etc That's why it is really tough to beat the OEM genuine ignition parts, they were engineered to work together.
You can reach your mileage goal, but you'll also have to really dig into both the distributor mechanical and vacuum ignition timing curve, and then finally some careful carburetor tuning & jetting work. If the ignition system itself is weak, it won't be able to reliably fire normal air/fuel mixtures so work on that first, make sure it's bombproof.
HandyDutchGuy
Sep 19, 2018 02:59 PM
BigCountry1978
18
Jan 11, 2016 11:06 AM
wollow007
55
Oct 24, 2015 03:30 AM
olddudeoldford
Jan 11, 2015 05:00 AM
slothshady
Sep 24, 2003 03:54 AM
