Knocking at 2000+
Old May 17, 2019 | 01:16 PM
  #31
F-ONE's Avatar
F-ONE
Along the lines of plug wire routing........
Look for silly stuff first. By silly I mean simple and not related to the rotating assembly of the engine. You say it is an odd sound so that opens up possibilities.
Exhaust leak at the manifold.....
Accesories. Alternator water pump....belts
loose covers or bolts...
Harmonics...like a tuning fork, at a certain vibration something starts to make noise and it may not be the engine.
motor mounts...
pipes...
pilot bearing...
something in the clutch assembly
cracked flywheel or flex plate
I too think you are on the right track but make sure it's not...silly stuff.
flex plate flywheel crack....
Old May 17, 2019 | 05:19 PM
  #32
BobbyFord's Avatar
BobbyFord
Fuel pumps have a damper spring on the lever. If the spring breaks it will make a noticeable tapping sound. Easy to isolate by stethoscope or a long screwdriver with the handle on your ear and the tip on the top most part of the fuel pump.
Old May 19, 2019 | 07:36 AM
  #33
jwitty's Avatar
jwitty
motor mounts...
pipes...
pilot bearing...
I’ve never looked at clutch/flywheel yet so maybe somethings weird in there. Shouldn’t be exhaust related. Just put on whole new system with headers and copper header gaskets. I’ve run it without the belt and still made noise. By harmonics, like could the harmonic balancer be bad?
Old May 19, 2019 | 07:37 AM
  #34
jwitty's Avatar
jwitty
It is a newer fuel pump I put on it, but could be a possibility. I’ll check it out also.
Old May 19, 2019 | 09:16 AM
  #35
john jamieson's Avatar
john jamieson
Those harmonics can really throw you. I thought something broke in my transmission from the grinding noise and vibration. It was a wheel bearing going bad.
86stepsideF150
30
Apr 30, 2019 08:00 AM
F350Man79
Jul 28, 2014 07:59 PM
turboguy
20
Oct 21, 2005 04:54 PM
fishmanndotcom
Mar 14, 2003 10:00 PM
