kinda scary noise... maybe timing issue?
Well... I've been hearing this noise for a long time now... Actually I have heard it ever since I dropped in my engine.
The noise sounds like something rattling around like if you had a piece of lead inside a metal ball and shook it.
The noise only occurs when the engine is under a lot of stress
Going up a hill in a low gear
OR
Jamming hard down on the throttle
It almost sounds like a loose/gummed up lifter or tappet?
The only solution or reasonable cause for the problem that I have so far heard of is that my timing is slightly advanced and it is causing for the lifters to go a little crazy now and again.
I do not know where my timing is currently set.
Any ideas? What should I check? I would try to listen to the noise from the engine bay but I never hear it at idle
Note: IT IS NOT A ROD NOCK>> i heard that on my last engine
OR
If it is only under hard acceleration or a heavy load, I am going to guess that it is spark knock. This is a result of the timing being too far advanced. You should adjust the distributor to retard the timing a few degrees. Do not let it continue to knock - it will cause engine damage the longer it goes on.
on
1 Post
If spark knock, then a number of fixes:
first and foremost, route the #8 plug wire out of the harness and along the intake, far far away from #7. Most people dont realize is that the truck 5.0 has the same firing order as a chevy and hence the same crossfire issues.
that said,
replace cap and rotor with the accel units. I found that pretty much every other brand out there has excessive rotor-tip to cap post clearance NEW. let alone used. That is a lot of wasted spark energy.
btw the clamshell heat shield that surrounds the stock converter likes to shed bolts and rattle.....go give it a rap.
that said,
I had the same problem woth my 5.0 1989 Bronco. There is a spark knock sensor buried back behind the intake manifold. It took me about 4 hours to change but cured the problem. I had to remove the upper plenm, coil and I did the valve cover gaskets as well since I was there. The sensor is mounted in the block between the tranny and the intake manifold. It is extremely difficult to see but you can kind of feel it. It is about a 1" socket style sensor. Set your timing after you change it. 10 BTC I believe. Best of luck.
https://www.ford-trucks.com/user_gal...=52797&width=0
That's a picture of the knock sensor location. Hopefully the link works. If not, it's in my gallery, the one about wiring diagrams.
I picked up a timing light today and will check my timing ASAP.
I use 87 octane gas and I am afraid that might be the culprit... I do have intake headers exhaust so that may upp my need for octane from what I understand...
is there a way to test if its the knock sensor is the problem? I dont want to spend all of that time and money to fix something that isnt broken...
on
1 Post
