Up pipe question.
Old May 14, 2019 | 06:24 PM
Ford.Dude's Avatar
Ford.Dude
Up pipe question.
Will an up pipe or exhaust leak preturbo cause high boost low power?
I'm having exhaust fumes enter the cab at stop lights or idle. I also have a whine which changes pitch with the throttle.
This seems like a minor leak to me but could it be the root cause.
Old May 14, 2019 | 09:50 PM
JaySVX's Avatar
JaySVX
A little exhaust goes a long way in terms of smell. Remember air is only 20% oxygen, the stuff we need, so it doesn't take a lot of contamination to make for a dangerous situation.
It would cause low boost and low power. Where are you, I have a brand new Y pipe you can have if you're close.
Old May 15, 2019 | 04:35 AM
Yahiko's Avatar
Yahiko
Yep you will loose pressure from the leaks so the turbine side of the turbo won't get the energy to spin the compressor side to give boost.
Do you have a tool to read live data? Look at the numbers for the EBP sensor. (Exhaust Back Pressure) You may find it lower or the VGT
might be able to deal with if it's small. However there is still the issue with exhaust fumes in the cab. Best to hunt that down and fix it quickly.
Remind me the year you have and if your deleted or not. I can post the PDF for you.
Old May 15, 2019 | 07:34 AM
Ford.Dude's Avatar
Ford.Dude
I've seen the ebp up to 50 psi. See the pic, may have to zoom in to see highest value. The LARGE map gauge is the actual boost.
Yeah Sean, deleted and straight piped.
I'm pretty certain the Y pipe isn't leaking. The only place I could possibly find was driver side where the y pipe meets the manifold and the manifold to head on one cylinder. No leak on rest. I tried to tighten the nuts but I fear the bolt will twist off if much more pressure is put to them. I'll purchase some hardened bolts before I start to really torque down on them in the event they do twist off.
Old May 15, 2019 | 07:35 AM
Ford.Dude's Avatar
Ford.Dude
Want to add that I'm NOT running a tune atm.
Knucks
Oct 7, 2016 04:32 PM
ATE88
6.4L Power Stroke Diesel
Dec 27, 2014 05:58 AM
Finz250
Apr 16, 2012 07:08 PM
Peterbilt376x
Oct 9, 2009 10:06 AM
7.3blacksmoke
Aug 27, 2008 01:28 AM
