Alignment cam adjusters?
Old May 13, 2019 | 10:52 AM
150 Beast's Avatar
150 Beast
I was just told my truck is out of alignment and needs to have “cam adjusters” added to it.
With 42k miles, something doesn’t sound right.
If they are right, what should it cost?
I was quoted $600.00
Old May 13, 2019 | 12:03 PM
GlueGuy's Avatar
GlueGuy
That sounds like apples and bananas to me. Alignment is wheels/tires/tracking. Cam adjusters is engine, and they aren't added, they're just there. Which year and engine are you talking about?
Old May 13, 2019 | 12:35 PM
150 Beast's Avatar
150 Beast
I believe he was using “cam” as an abbreviation for “camber”
2015 F150
Old May 13, 2019 | 12:36 PM
scott91370's Avatar
scott91370
Sounds like you need a new shop.
Old May 13, 2019 | 01:20 PM
ford390gashog's Avatar
ford390gashog
2015 F150
The kits are right around 35.00 a side and easy enough to install. I had to install them when I did my leveling kit because I was still 1.5 degrees out. I would never pay 600 for install.
Old May 13, 2019 | 01:47 PM
150 Beast's Avatar
150 Beast
I had a feeling that price was way off. He told me the camber adjusting bolts were $400 and right then I knew something was fishy and this was a dealership by the way
Old May 13, 2019 | 03:33 PM
JKBrad's Avatar
JKBrad
My leveling kit, installed and aligned with camber adjusters, was $300. Take it to an independent shop.
Almost every truck, new or old, will need the alignment cams when the time comes.
Old May 13, 2019 | 05:43 PM
150 Beast's Avatar
150 Beast
I just YouTube’d it. Is it really that easy?
I’m very mechanically inclined....
Old May 13, 2019 | 06:08 PM
150 Beast's Avatar
150 Beast
Found them on Rock Auto
Old May 16, 2019 | 02:31 PM
150 Beast's Avatar
150 Beast
Is 2 bolts per side all that’s needed in the upper control arm or, does the lower arm get them too?
Old May 16, 2019 | 02:49 PM
JKBrad's Avatar
JKBrad
No, they go on the lower control arms. 2 bolts per side, 4 total.
Old May 16, 2019 | 04:30 PM
150 Beast's Avatar
150 Beast
Thank you!!!
Old May 16, 2019 | 06:07 PM
GlueGuy's Avatar
GlueGuy
https://youtu.be/OsizWChLOQw
I watched it, and I think he placed the washers incorrectly. The washers should go under the bolt head (or nut) and not between the cam washer and the control arm mount. You want the maximum amount of friction under the cam washer.
ghunt
Modular V8 (4.6L, 5.4L)
Feb 10, 2016 03:21 PM
wmiller
Aug 21, 2009 04:51 PM
debestuss
Mar 16, 2005 03:51 PM
kritterkraz
May 18, 2001 02:40 PM
