Would you run this cam?
Old Feb 9, 2016 | 11:33 AM
ghunt's Avatar
ghunt
Guy offered to sell me his Hot Rod cams that he had swapped out a couple days ago.
When the shop pulled the cams out they found unusual wear on one of the lobes as shown in the picture. Is this cam still OK?
Old Feb 9, 2016 | 01:50 PM
davester250's Avatar
davester250
You can see the marks, can you feel them with your finger?
yes, with the caveat that I'd measure the lift and see if the peak has been worn any [even just compare it with other lobes for the port (intake or exhaust)].
Old Feb 9, 2016 | 03:18 PM
ghunt's Avatar
ghunt
Guy says it doesn't catch a fingernail.
I'm not familiar with what constitutes "normal" wear for a cam, but I would think wear like this on a roller cam would be a bad sign.
Old Feb 9, 2016 | 03:49 PM
Beechkid's Avatar
Beechkid
The wear pattern although my be only visual it is identifying a potential issue that was likely with the donor engine valvetrain and secondly and new cam is cheap insurance.
Old Feb 9, 2016 | 04:12 PM
ghunt's Avatar
ghunt
Well...Hot Rods aren't cheap unfortunately, this guy had initially offered to sell them to me for a really good price (before they were out of his car).
My gut's saying to pass on them...shame, they were such a good deal.
Old Feb 9, 2016 | 07:33 PM
davester250
It's not normal for the cam to look like that, it looks like that because the roller lifter running on it wasn't rolling like it should [jammed, didn't get oil, failed].
If the lobe is smooth and the right height, it's fine. There's nothing for the new roller-lifter to catch on, and the cam isn't going to break in half because of this.
If you want to use the rest of the motor, I'd figure out why the lifter failed [did it fail on it's own, was it getting oil, rest of the lifters are ok].
Old Feb 9, 2016 | 09:22 PM
ghunt's Avatar
ghunt
I'm not buying an engine, the guy offered to sell me the cams.
Old Feb 9, 2016 | 10:48 PM
davester250
To me, if the lobe height is the same as the rest, there's no way for those markings to cause a problem running the cam in another engine with lifters that are working properly..
Old Feb 10, 2016 | 11:26 AM
Beechkid's Avatar
Beechkid
Look at it this way......a destroyed valvetrain & heads is $2k....new cam & kit...$400...cheap insurance....also, while the lifter appears to be the blame/cause, let's not forget the potential for metal fatigue in that cam lobe itself.
Old Feb 10, 2016 | 03:21 PM
ghunt's Avatar
ghunt
Hot Rods new are more like $700. But yes, if it grenade the engine I would be out significantly more.
Well, the guy won't answer my questions so at this point it's probably moot.
ng19delta
15
Jan 1, 2017 04:51 PM
ygoldsberry
Mar 25, 2012 10:41 AM
wmiller
Aug 21, 2009 04:51 PM
kopfenjager
Dec 29, 2005 01:25 AM
fordman428
Dec 5, 2003 03:51 PM
